Do not die. Learn these driving ideas and you will appear to be a master of your own driving area. Will you be trying to sell or purchase a used or new car? If this sounds like you, get a quote at Gus Johnson used cars! Want to know find out more about Gus Johnson Ford? Check out this! Avoid your car with adjusting The best way to stay away from accidents depending on your blind spot is to adjust the mirrors. People do not realize you can actually see your blind spot if you change your mirrors so that you cannot see your own car. It is unnecessary to get fancy gadgets that are fairly expensive in case you are just willing to do this. It will only take you a few minutes before you head out on your trip and will work out well. Driving tips for survival No. 2 - Don't read the signs, read the traffic Drivers are better at adapting to road situations when there are no road signs, according to multiple studies. Intersections that had no signs or traffic lights were safer than other ones. You will be much better off paying attention to the road and the vehicles around you than you will make an effort to figure out what the sign is saying. Yes, the signs are helpful, but it is still better to pay attention to the road. Avoid listening to music A study conducted by Israeli researchers found that test matter drivers tended to get a more level heart rate when listening to music. This may seem like these motorists were calmer and would perform better on driving tests, but the truth is that in the presence of music, they were less focused on driving. Thus, they were more likely to run red lights. When the music was of a higher tempo (between 120 and 140 beats per minute), this problem was accentuated. Car headlights in use all the time A recent study indicates that if a car's headlights are constantly on while the vehicle is driven, the chance of being involved in an accident decreased by 32 percent. Other motorists tend not to pull in front of you if they can see the glare of headlights. Pedestrians and cyclists are similarly hesitant. To Get The Top Rated Offer On A brand new Car, Van, Truck or SUV Just Go To Miller Dodge Chrysler Jeep Springfield Pa! Driving tips for survival No. 5 - Use the parking brake Everything in your car needs to get used regularly if you would like to avoid corrosion and rust on the cords and cables running through your car. One example of this is the parking brake. The cable will rust if it is never used making it impossible to use when you need it. Use it regularly, and also you may just protect your car. With regards to auto lending, you cannot get it too early Driving suggestions for survival No. 6 - Don't slam on the brakes during a blowout Your car will fishtail and possibly flip if you slam on the brakes during a tire blowout. This is the natural response, but it is important not to do it. Keep your automobile on a straight line to keep control and hit the gas firmly for a couple of seconds. Turn into the blown tire and the car will slow on its own. Sources Car and Driver Cracked Edmunds
