Here are the pics... You can see the difference between the two..the wilwood is HUGE The Honda pin is so easy to depress compared to the wilwood. I had to add several washers to the bolts just to get it to clamp to the bracket. Neither bolt is lined up ON the bracket...probably need a new one or an additional piece added. Take a look at the stock photo. The bolts would have to be removed because they are not threaded all the way down and we'd run out of threads, Unless...we bolt it to the car like the MC is...haven't looed to see how it lines up underneath. Probably would not work but worth a look.
