MrKona |
Senior Member ![]() ![]() ![]() Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None ![]() |
I finally acquired a set of SS heat exchangers to replace my rusty originals. With some Mother's, they are shining up beautifully. (IMG:style_emoticons/default/drooley.gif)
One of them has thick, baked on oil stuck to it. What should I use to get this stuff off? Oven cleaner? Carb cleaner? Anyone have any words of wisdom? Thanks! - Bryan |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
simplegreen works great too...
give it a try before you hit the nastyer solvents.... (carb cleaner/brake cleaner / acetone/ laqueur thinner / MEK etc...) |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
One of them has thick, baked on oil stuck to it. What should I use to get this stuff off? Oven cleaner? Carb cleaner? Anyone have any words of wisdom? Thanks! brake cleaner. get a few cans, spray generously, let sit for a few minutes and it'll come right off with a old shop-rag ... and try not to sniff too much of that stuff ... (IMG:style_emoticons/default/wacko.gif) Andy |
MrKona |
Thanks Aaron. I'll soak it with some Simple Green right now and check on it in the morning so see if it's softened up.
MrKona |
One of them has thick, baked on oil stuck to it. What should I use to get this stuff off? Oven cleaner? Carb cleaner? Anyone have any words of wisdom? Thanks! brake cleaner. get a few cans, spray generously, let sit for a few minutes and it'll come right off with a old shop-rag ... and try not to sniff too much of that stuff ... (IMG:style_emoticons/default/wacko.gif) Andy Alright... Simple Green for starters, and if that doesn't work, brake cleaner with the garage door wide open... Thank you! |
BigDBass |
Dumb Question Champion ![]() ![]() ![]() Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest ![]() |
What Mother's product were you using for this?
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
Wire brush on a polishing angle grinder.....
martinef1963 |
The Saga Continues... ![]() ![]() Group: Members Posts: 320 Joined: 9-November 04 From: Miami, FL, USA Member No.: 3,080 Region Association: South East States ![]() |
I took them and had them sandblasted which took care of the exterior stuff, then had them baked for ceramic prep.
They came out awsome, but this road I took to save time and elbow grease, not the road to take if your trying to save some $$$$ They look sweet though, here are some pictures: Attached image(s) ![]() ![]() |
pfierb |
oldest member ![]() ![]() ![]() Group: Members Posts: 606 Joined: 1-May 05 From: The sign of good government in Connecticut is to keep raising taxes Member No.: 4,008 ![]() |
Try Oven Off....cleans up most nasty stuff.....wear rubber gloves
IanStott |
Member ![]() ![]() Group: Members Posts: 226 Joined: 13-June 04 From: Moncton,New Brunswick,Canada Member No.: 2,199 ![]() |
I used the Bug & Tar remover that you can buy in the same section you get car wax at Walmart, worked great and I was comfortable knowing it was not too aggressive as it is the stuff you can use on your paint or chrome bumpers.
Ian Stott Moncton Canada |
D1A3 |
Gruppe Neun Vierzehn Südosten ![]() ![]() Group: Members Posts: 362 Joined: 3-June 04 From: Atlanta, GA Member No.: 2,152 Region Association: South East States ![]() |
PORobinSCHE |
Member ![]() ![]() Group: Members Posts: 421 Joined: 22-July 06 From: Orlando,Fl Member No.: 6,484 ![]() |
a cheap way to clean them is first coat liberally with Gunk. the use an SOS pad to remove the stubborn stains.
if you want the S/S to shine afterwards, use Mother, Flitz,Renol,or any metal polish and a XXX(extra fine) steel wool pad. it will take awhile,but can be made to shine like chrome.. Robin |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
don't forget to flush out the inner portion of the hes while you're at it.
Pat Garvey |
Do I or don't I...........? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States ![]() |
All the products mentioned will work, particularly if you give some soak time. I'd use brake cleaner instead of carb cleaner, but that's just me, and after soaking for a while with Gunk. Very fine steel wool will wipe out any remaining stain, without scratching deeply, but I'd use it on the entire exchanger.
Then you can use whatever metal polishing compound you'r happy with - there are a number of good ones. I prefer Simichrome because it leaves a slight protective coating behind. Pat |
MrKona |
Thanks for all the suggestions.
I just gave them a shot of brake cleaner. Got off some crusty stuff, but those fumes, even outdoors, or scary. (IMG:style_emoticons/default/wacko.gif) I think I'll hold off from using that again. So now I'm letting them sit with Easy Off foam, the "no scent" type, which has a nice "lemony" scent. (IMG:style_emoticons/default/huh.gif) I'll try wiping them down in a few hours. Once they're clean, I'll shine them with Mothers metal polish. I have a big tub of it in the garage. I'll post 'before' and 'after' pics when it's all done. |
MrKona |
Alright here's the "before" and "after" pics. The oil was really, really thick and rock-hard baked on, but after several applications of Easy Off, extra fine steel wool, wire wheel on drill and Dremel, and Mothers metal polish, here is the result:
- Bryan Attached image(s) ![]() ![]() ![]() |
Joe Bob |
Pretty.....
swood |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None ![]() |
pretty crunked out...just like ma grill!
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
Those came out great.
mills914/s |
Member ![]() ![]() Group: Members Posts: 253 Joined: 23-December 06 From: Coeur D'Alene... IDAHO Member No.: 7,363 Region Association: Northern California ![]() |
Good job they came out great. (IMG:style_emoticons/default/clap56.gif)
I need a set of those. Mine are super rusty and ugly |
Lo-Fi Version | Time is now: 10th June 2024 - 09:46 AM |
