Front brake rotor offset, cross over years suck!!! |
Jaiden |
Mar 20 2006, 05:43 PM
Member Group: Members Posts: 346 Joined: 13-January 05 From: Stroudsburg PA Member No.: 3,443 |
Hey all. I got most of the front suspension back on but when I went to put the brake calipers on I noticed that they would not fit over the rotor AND lined up with caliper mounts. SO I removed my new rotors and compared them to the old and found that the rear offset from the rotor surface to the bearing seal surface is deepr on the original rotors.
I had to find this out after I already pressed in the ew bearing races (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) So how can this be? I have the old style strut tubes. When I talked with eric shea about getting my calipers we stated that I have "new" style calipers So what did the factory do? Old strut tubes and new style brakes on a 72? I guess I gotta order new rotor and pull out the races qand return the rotors. Man I hate set backs |
Eric_Shea |
Mar 20 2006, 06:08 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
There was always this question and it looks like you're on the verge of solving the mystery.
You "do" have new style calipers, that's for sure (dual bleeders, fasteners that terminate in the machined nose half) and if you have a bolt at the bottom of your strut vs. a pin then you have the old style struts. So... for those with crossover year cars, look for the new style caliper and make sure you order the later rotor with the centering ring. This also means that calipers and rotors are interchangable if done so as a 'set'. For others out there reading this; Base your rotor purchase off your caliper not your strut. Sorry you're having problems. You 'may' be able to tap (lightly) that race out and use it in the new rotor. |
Cap'n Krusty |
Mar 20 2006, 06:13 PM
Late tubes require late calipers and rotors. Early ones require early calipers and rotors. There are NO other combinations, AFIK, so you better be sure where you put your money! The Cap'n
Eric_Shea |
Mar 20 2006, 07:05 PM
When you say tubes you mean struts?
I no longer believe that to be correct. I think they're interchangeable as long as you bring the rotor with the caliper -or- caliper with the rotor. The system that was up and running on his car was new calipers/new rotors and old struts. |
Eric_Shea |
Mar 20 2006, 07:07 PM
Unless! There's a weird one off mid-year strut that has the old style ball joint and uses the newstyle rotors and calipers. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Cap'n Krusty |
Mar 20 2006, 07:09 PM
Unless further evidence pops up, I stand corrected. The Cap'n |
Eric_Shea |
Mar 20 2006, 07:17 PM
I know what you're saying... that's what I thought too but; I've heard rumors to this and it looks to be the case. Looks like James is proving it out with his mid-year mobile.
James, fill us in when you get everything bolted together. I have your cores and those are new style as well... I just verified that against both old and new style offsets here. |
Jaiden |
Mar 20 2006, 10:20 PM
Well I definitly have the "old style" strut housings which have the bolt on the bottom not hte pit and nut and I DO have the "new style" calipers as referenced by eric. I also ordered the "old style" rotors but did not check until assembly. My only hint before install was erics comment about the "new style" calipers. SO I guess either I have an "n ew style" spindle on the "old style" strut housing OR they are interchangeable if you switch the caliper and rotor at the same time.
From this pic you can see the "new style " calipers, and notice how close the rotor runs to the dust sheild. The "old style" rotors that I ordered sit about 1/2 inch farther away from the shield than this pic. (IMG:http://www.914world.com/bbs2/uploads/blog-1138974262.jpg) |
Chris Pincetich |
Mar 21 2006, 12:59 AM
Gotta love the '72! (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
I cross my fingers with every part order, cause it may be the "late", it may be the "early", or it may be one of each (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) I've been enjoying all the suspension posts- keep up the good work! (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
davep |
Mar 21 2006, 06:48 AM
914 Historian Group: Benefactors Posts: 5,154 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Don't forget there was the interim rotor. IIRC it was late offset but without the hub-centric ring. Not sure if that was the only difference.
SLITS |
Mar 21 2006, 07:50 AM
Here's something else for ya'll to smoke....A1 Cardone, when rebuilding calipers, will take a single bleeder (supposedly early) and drill/tap it for the second bleeder (which makes it look/function like a "late" caliper). I asked why and they didn't have an answer.
Eric_Shea |
Mar 21 2006, 09:21 AM
Couple of things:
James... you may be in for more fun. Take what Dave said and look at your later style rotor that's in the picture above. "No Centering Ring" (that I can see from the picture). Regarding the A1 boys; Slits mentioned that to me before which may explain some of what I call 'cross over' calipers. I've only seen them as rears but they have dual bleeders and through bolts. The bleeders didn't look like an afterthought though... if they did it, they did a good job. (also... the next time you start a line with "Here's something else for ya'll to smoke...." and you're located in the "California Mountains" I'll be expecting somthing a little better than a 'dual bleeder' story!) (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif) So... if those are the rotors that Dave is discussing you have two options now: 1. Go to the nearest machine shop and have your centering ring machined off. We do that with the front 5-lug rotors for later cars. 2. Get yourself some nice 'later' wheels and never worry about it again. (it will all be over soon...) |
Jaiden |
Mar 21 2006, 09:44 AM
I have empi's so I don't think that the centering ring would be a problem.
Here are the wrong rotors that I got. (IMG:http://www.914world.com/bbs2/uploads/blog-1142386063.jpg) |
Jaiden |
Mar 21 2006, 09:45 AM
tat2dphreak |
Mar 21 2006, 09:50 AM
from the info in my notes:
The factory changed the strut housing, ball joint, caliper and rotor at VIN 4722919032 if the VIN is after that, it's the same as a 73+... I've changed all of the front end pieces that are replaceable as maintenance and that has held true... basically the entire front end is a 73 except no sway bar... the U-tabs are there for the bar though... |
Jaiden |
Mar 21 2006, 10:36 AM
I'll check my vin and get back to you
Spoke |
Mar 21 2006, 10:55 AM
Jerry Group: Members Posts: 6,992 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I did this when I ordered new rotors. The bearing set on the driver side was replaced about 1 year ago on the old rotor. I used a brass drift to remove the "good" bearing races which did not damage the races at all. Also used the drift to tap in the races on the new rotors. On the other rotor I purchased new bearings from my local NAPA store. Spoke |
Eric_Shea |
Mar 21 2006, 03:00 PM
I don't think that matters. From what I see here, they'll probably list your car as the 'new' version. It has new calipers and hence new rotors. From what I can see, there is no change in the spindle over the years, just the bottom where the ball joint attaches. This follows what we've seen to be SOP at the factory... use what you've got until it runs out. This was my initial post about solving the crossover-car mystery. I'm going to go out on a limb and say it's solved: You can interchange calipers and rotors 'only' if done together. New style calipers must have new style rotors. The strut is irrelevant. |
Eric_Shea |
Mar 21 2006, 03:04 PM
One more thing... the ball joint in your blog is "new style". This doesn't jive with your struts. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
Eric_Shea |
Mar 21 2006, 03:15 PM
Here's a blog pic that shows all:
New Caliper Old Strut New A-Arm Now I'm concerned about the ball joint. |
Lo-Fi Version | Time is now: 11th June 2024 - 08:07 AM |
