| Kaduku |
Mar 28 2013, 11:37 PM
Member ![]() ![]() Group: Members Posts: 344 Joined: 1-January 13 From: SF Bay Area Member No.: 15,324 Region Association: None |
Before I go on, I must say that compared to my MGBs, removing the seats were so freakin easy. I have owned BMWs and Mercedes Benzs for many years, but I have only realized how smart these Germans are when it comes to engineering.
So I am ready o remove the back pad. I know that after removing the screws in the bottom, I must lift up and out to get the back pad out. I must also disconnect the vanity light connection, but what about the lid release knob? |
| ndfrigi |
Mar 28 2013, 11:53 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,995 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California
Before I go on, I must say that compared to my MGBs, removing the seats were so freakin easy. I have owned BMWs and Mercedes Benzs for many years, but I have only realized how smart these Germans are when it comes to engineering. So I am ready o remove the back pad. I know that after removing the screws in the bottom, I must lift up and out to get the back pad out. I must also disconnect the vanity light connection, but what about the lid release knob? Yes you need to remove it also. Unscrew it by pulling the knob then use something to hold the line and turn the knob. |
| 914socal |
Mar 28 2013, 11:57 PM
Newbie ![]() Group: Members Posts: 38 Joined: 18-October 12 From: Santa clarita Member No.: 15,059 Region Association: None |
Before I go on, I must say that compared to my MGBs, removing the seats were so freakin easy. I have owned BMWs and Mercedes Benzs for many years, but I have only realized how smart these Germans are when it comes to engineering. So I am ready o remove the back pad. I know that after removing the screws in the bottom, I must lift up and out to get the back pad out. I must also disconnect the vanity light connection, but what about the lid release knob? Yes you have to disconnect the lid release knob. It should unscrew counter clockwise. It also helps to unscrew the lower set belt at the body. |
| ejm |
Mar 29 2013, 04:00 AM
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,719 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
| JawjaPorsche |
Mar 29 2013, 06:19 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
Stating the obvious: You will need to remove your seats and center tray too. Someone on 914World turned me on to removing the seats without unbolting. Just slide the seats as far as possible to the dash, then reach under the adjustment track and push up and continue to push the seat forward. It will slide off completely! I wish I had learned that sooner! (IMG:style_emoticons/default/biggrin.gif)
| SUNAB914 |
Mar 29 2013, 06:20 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
Make sure you label your seatbelts (L&R) and don't loose the washers. Keep everything in order.
| rpmmaxxed |
Mar 29 2013, 06:28 AM
Member ![]() ![]() Group: Members Posts: 387 Joined: 24-May 05 From: Oceanside, CA Member No.: 4,140 Region Association: Southern California |
| type47 |
Mar 29 2013, 07:20 AM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
| Kaduku |
Mar 29 2013, 08:03 AM
I did not know I had to remove the center tray too (IMG:style_emoticons/default/blink.gif)
Thanks everyone! |
| TheCabinetmaker |
Mar 29 2013, 08:43 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,378 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
. Interesting post Jim. (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/happy11.gif) |
| TheCabinetmaker |
Mar 29 2013, 08:45 AM
Not necessary to remove seat belts to remove backpad.
| Kaduku |
Mar 29 2013, 09:13 AM
| Valy |
Mar 29 2013, 11:38 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
I hope you're not trying to install retractable seat-belts on an early car originally fitted with fixed ones.
The firewall is different. |
| Kaduku |
Mar 29 2013, 11:45 AM
| TheCabinetmaker |
Mar 29 2013, 12:14 PM
All good.
| Kaduku |
Mar 29 2013, 07:11 PM
HELP.......... okay got everything off. How do I get the new seat belt to un-retract? It is not installed yet.
| Dave_Darling |
Mar 29 2013, 09:36 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,365 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
It has to be vertical, like it would be in the car. There is a pendulum that actuates the locking mechanism, intended more for detecting deceleration than tilting.
--DD |
| CG-914 |
Mar 29 2013, 09:51 PM
Member ![]() ![]() Group: Members Posts: 327 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
(IMG:style_emoticons/default/hijacked.gif)
Removed the back pad before and everything (IMG:style_emoticons/default/agree.gif) no seatbelt removal necessary! Any tips for fixing the retracting mode? Mine are hard to pull out, they stop all the time... |
| Kaduku |
Mar 29 2013, 10:30 PM
It has to be vertical, like it would be in the car. There is a pendulum that actuates the locking mechanism, intended more for detecting deceleration than tilting. --DD Well, I bolted them on then grabbed the belt with two hands, braced my foot on the threshold and pulled like hell. (IMG:style_emoticons/default/w00t.gif) Slowly but surely it started to loosen. It took a few times to pull it back and forth until it retracted freely. I now have a working driver's seatbelt (IMG:style_emoticons/default/aktion035.gif) The only small thing is that my new one is chrome (NOS from AA) at the top loop and the passenger side is black. The plastic cover does hide some of it but not all. Next step while the back pad is off is Dynamat. |
Lo-Fi Version | Time is now: 5th November 2026 - 06:07 PM |
