901 transmission tail cone gaskets $5, If you don't need an entire set why pay $35? |
Mikey914 |
Oct 6 2009, 12:11 PM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I made these at the prompting of Dr. Evil. Though it would be nice not to have to buy an entire set to crack the case open. As the good doctor will not be able to use the supply I have created before retirement thought I'ld make these available to all!
$5 each. Attached thumbnail(s) |
tat2dphreak |
Oct 6 2009, 12:15 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
(IMG:style_emoticons/default/smilie_pokal.gif) you are the man!
brant |
Oct 6 2009, 12:33 PM
914 Wizard Group: Members Posts: 11,628 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
are they the same thickness of material as the originals?
I once had a problem using a thicker (too thick) of gasket I'm very interested in 4 of them, if they are the exact thickness of the originals brant |
Mark Henry |
Oct 6 2009, 12:41 PM
PM sent I'll take 4
Bet they are the right thickness, Doc told me they are Evil Approved |
jhadler |
Oct 6 2009, 12:48 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Just trying to remember here... The tail cone gasket thickness is critical for backlash setting right? Do these gaskets come in different thicknesses? Not all backlash is the same...
-Josh2 |
brant |
Oct 6 2009, 12:50 PM
Just trying to remember here... The tail cone gasket thickness is critical for backlash setting right? Do these gaskets come in different thicknesses? Not all backlash is the same... -Josh2 its really the intermediate plate gasket that is critical for back lash. but the tail cone is less critical... still, I once had a problem with too thick of a gasket so.. anything real close to stock should be good enough.. let us know payment and shipping details thanks a ton brant |
Mikey914 |
Oct 6 2009, 12:56 PM
These are the same thickness as OEM, same material too.
Mikey914 |
Oct 6 2009, 12:57 PM
Just trying to remember here... The tail cone gasket thickness is critical for backlash setting right? Do these gaskets come in different thicknesses? Not all backlash is the same... -Josh2 While I could make them in diferent thicknesses, it's not cost effective, so I went stock. |
Rotary'14 |
Oct 6 2009, 03:52 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
Can you make the different thikness' for the intermediate plate for a reasonable price too?
-Rob |
lotus_65 |
Oct 6 2009, 05:27 PM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
i'll take 4 if you haven't shipped my windshield seal yet.
Dr Evil |
Oct 6 2009, 09:22 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Rob, if you need int plate ones I have a shit load. You dont use them all in a a rebuild so there are always extras. PM me if you need them. It isnt worth it for Mark to make them, IMHO.
As for the tail cone gasket, I have one of the first run ones and I did send Mark a stock one to go off of. These are gonna be a great resource for us and I am glad that Mark stepped up and did them even when I didnt have the time/$$/etc to buy them all. I am going to pimp these to AA this weekend as well. It would be nice to save $30+ on the seal kit (IMG:style_emoticons/default/smile.gif) |
tat2dphreak |
Oct 6 2009, 09:28 PM
ok, I have not done a transmission rebuild, yet... is 4 required?
Dr Evil |
Oct 6 2009, 09:47 PM
If you buy a seal kit for a rebuild then you dont need any as the kit has one. BUT, if you are like many and just want to fix 1st gear then you just need to pull the tail cone which requires this gasket only. You only need 1 per tranny (IMG:style_emoticons/default/wink.gif)
Mark Henry |
Oct 6 2009, 10:01 PM
tat2dphreak |
Oct 6 2009, 10:02 PM
ok, I was just wondering why everyone wanted 4 (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 29th May 2024 - 03:11 AM |
