Can someone measure their late style engine lid?, need dimension between rain tray mount points |
Brian_Boss |
Oct 10 2009, 01:07 PM
Member Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 |
While my engine lid is off, I am modifying it for the late style rain tray. The tray I have is a little warped so I would rather not use it to set the mounting points.
Can someone with a late lid measure the fore and aft distance between the mounting holes? I think both sides are the same but please measure both to be sure. Thanks |
Jakeodoule |
Oct 10 2009, 01:24 PM
Member Group: Members Posts: 353 Joined: 10-October 08 From: Des Moines Iowa Member No.: 9,630 Region Association: Pacific Northwest |
While my engine lid is off, I am modifying it for the late style rain tray. The tray I have is a little warped so I would rather not use it to set the mounting points. Can someone with a late lid measure the fore and aft distance between the mounting holes? I think both sides are the same but please measure both to be sure. Thanks 185mm Driverside 230mm middle 187mmPass side These are from a 75 lid Jake |
Jakeodoule |
Oct 10 2009, 01:27 PM
Hard to believe they are that dif, but I measured them three times.....
Brian_Boss |
Oct 10 2009, 03:21 PM
Thanks - that was quick. Part of the reason the center dimension is greater is that the holes are not parallel to the centerline.
Anyway, all done. Your measurements make sense because the driver's side comes out pretty much dead center on the diagonal reinforcment. Here is the piece I had to add for the passenger side. |
Lo-Fi Version | Time is now: 9th June 2024 - 06:53 PM |
