air flap ?, which part is it mary needs? |
tat2dphreak |
Oct 17 2009, 08:37 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
Air Flap 914 559 163 10 1
is that the coling flaps in the fan shroud? if so I will send her the one I just took out. I'll bead blast it and paint it first tho. one more thing. I found out the heater hoses there are some cheap substitutions.... the rear heater hose off a 911 is about $20 and can do all of the front heater hoses in one length. mikey914 also makes the ones that go from the blower to the j-tubes... hope that helps |
EdwardBlume |
Oct 18 2009, 05:45 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
Air Flap 914 559 163 10 1 is that the coling flaps in the fan shroud? if so I will send her the one I just took out. I'll bead blast it and paint it first tho. one more thing. I found out the heater hoses there are some cheap substitutions.... the rear heater hose off a 911 is about $20 and can do all of the front heater hoses in one length. mikey914 also makes the ones that go from the blower to the j-tubes... hope that helps I have an extra fan shroud off a 2.0 laying around if that helps... |
ejm |
Oct 18 2009, 06:49 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,694 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
QUOTE Air Flap 914 559 163 10 1 I took a look at PET this am and couldn't find this part. Just took another stab at it and realized the part # can't exist. Without the "1" at the end the format is correct but that # is not in the factory price book. The p/n starts with 914 so it is specific to the car. Most if not all of the engine stuff would be 021/022 since it was sourced from VW. I could be wrong (IMG:style_emoticons/default/confused24.gif) A pic of the part would be good (IMG:style_emoticons/default/smile.gif) |
Kansas 914 |
Oct 20 2009, 10:10 PM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
QUOTE Air Flap 914 559 163 10 1 Guys, That part number came from Carrie Sweet - not sure what she meant - but let's wait until the engine builder (and Ed) tells us what is needed - Carrie may have made some assumptions from the 30 foot view - without tearing into the engine. Does that makes sense? |
ejm |
Oct 21 2009, 12:56 PM
Got it. This is the plastic air deflector that's under the car at the rear edge of the floor pan. The part # is correct, the "1" must be quantity as there are two of them. This part is long NLA and is no longer listed in my price book.
EdwardBlume |
Oct 21 2009, 02:56 PM
Pretty sure I have a spare off 504 as I remember the bolt being small. Is it one side fits all?
tat2dphreak |
Oct 21 2009, 03:28 PM
I don't even know that part... it's probably not on my car (IMG:style_emoticons/default/biggrin.gif)
ejm |
Oct 21 2009, 03:33 PM
I don't even know that part... it's probably not on my car (IMG:style_emoticons/default/biggrin.gif) that's right.... factory installed on '73 and up... you will get better engine cooling with them Rob...same part both sides |
EdwardBlume |
Oct 24 2009, 09:04 PM
Got 2 of them. Cleaned up OK after this pict... right parts right?
Attached thumbnail(s) |
ejm |
Oct 25 2009, 05:42 PM
QUOTE ... right parts right? yep |
Lo-Fi Version | Time is now: 9th June 2024 - 08:28 PM |
