Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
Has anyone used an aftermarket oil tank and mounted it say....in the rear trunk or up front? If so, who made it....?
I'm thinking of doing it because of PRICE, fittings (AN) and better weight distribution.... |
TimT |
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 ![]() |
I had one made for my 911. It cost $350, and it fits in the smugglers box without ANY cutting. You could sketch a tank with dimensions that you want and have a place like Howe Racing make it for you, Coleman might make them also.
Oh my tank is less than 1/2 the cost of the Smart Racing tank, and it fits w/o cuting, unlike the SRP tank oil tank Attached image(s) ![]() |
TimT |
Here it is fit in a 935 clone
you just have to pic a spot, then design the tank to fit Attached image(s) ![]() |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
QUOTE(mikez @ Mar 15 2004, 07:34 AM) Has anyone used an aftermarket oil tank and mounted it say....in the rear trunk... drysump oil tanks must be tall and thin. i think you'd have packaging problems with a rear trunk mount. the front has issues with hot, expensive oil lines running past or through the cabin, but the volume of the lines might let you get away with a slightly smaller tank. i think if i were looking to relocate something, i'd move the battery to the front and mount a tank in the space vacated by removing the battery tray and support, and as deep as possible. good for cg, keeps the lines short, and the heat in the engine room. once upon a time, ATL made oil tanks, maybe Moroso too. |
Joe Bob |
Battery has been relocated to the cockpit behind the passenger seat, puke box for the breather is mounted on the wall above where the battery was....not a real problem to move....-12 AN oil lines are already run to the front mounted cooler.
TimT |
there is this option also, this I believe is a petersen tank
Joe Bob |
Who be Peterson? Got a retailer or contact for information them?
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Mike,
don't move the tank rearward for a race car.... its a trade off with stock versus front.. but don't move the weight backwards..... b |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Does't Motormeisters make a six tank that sits where the battery tray was. Eddie914 has on in his 914/6 track car. The weight would be decent with the tank there as it offsets some of the drivers weight side to side. (IMG:style_emoticons/default/smash.gif)
Geoff |
Van914 |
Van914 ![]() ![]() ![]() Group: Members Posts: 698 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest ![]() ![]() |
Zois,
Are you going to run a fuel cell? If so mount where the stock gas tank is. Run the lines through the pass. side longs and heater tubes. It will keep most of the heat from the oil lines out of the interior. You have shorter runs to the cooler. The vent from the enging can be ran to the tank also. Van914 |
Joe Bob |
Current setup has a stock tank but I'm leaning towards a fuel cell. The front trunk holds the internally mounted oil cooler with a cowl over it behind a 916 style front bumper.....I might move the cooler up in front behind a 75-76 rubber bumper cap w/o the heavy steel support......
Still exploring options by using my experience and others to do this low price like. |
Van914 |
Mike,
I will try to get some pictures fo my friends race car. It has the tank mounted where the stock fuel tank was and a fuel cell in the spare tire well. The front RX-7 oil cooler is vented through the hood. Van914 |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
One of the locals has a prototype MSHP oil tank sitting where his battery tray used to. Works great for him. I thought I had pics from one of the Roadglue breakfasts, but I can't find them.
There are a number of aftermarket "swirl pot" type tanks you can buy. Check through the large racer's catalogs. Many are baffled as well, though a tall skinny tank doesn't need the baffles as much. Figure out how much space you can devote to it, then start looking at the catalogs. --DD |
d914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,331 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States ![]() |
pegasus has them, Patrick's( he says tentatively) ??
Joe Bob |
QUOTE(d914 @ Mar 15 2004, 09:30 AM) pegasus has them, Patrick's( he says tentatively) ?? Patrick....yeah, that'll happen. Looks like Brad may have a stock one for a decent price.... |
Downunderman |
Senior Member ![]() ![]() ![]() Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand ![]() |
If you find a stock tank its not a big deal to cut the fittings off and replace the return line with a -12 weld on male and same with feed line -16. I just changed mine over to this set up over the last few weeks.
Joe Bob |
Tank is easy....the bitch is the lines coming off the engine.
TimT |
thesey914 |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 ![]() ![]() |
Where does the filter mount on these tanks? (IMG:style_emoticons/default/confused24.gif)
TimT |
You have to mount the filter seperately. This gives you a wide choice of filters you can use..Like theCanton or Oberg filter, Or you can out the 964 oil cooler retrofit and use the 944 filters (or 964 filters)
Lo-Fi Version | Time is now: 16th June 2024 - 11:00 PM |
