Parking Brake Light Not Going Out |
kenshapiro2002 |
Oct 21 2009, 10:06 AM
Senior Member Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
Well...it diminishes by about 50%. What might be up with that? The light wasn't working at all when I got the car. The switch, under the handle needed some cleaning and lube, and then operated prefectly up until my drive today. Brake seemed to be all the way released since she rolled easily on a slight incline, but the light only dimmed...didn't go off.
URY914 |
Oct 21 2009, 10:12 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,979 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Check the little nipple on the switch under the handle. Sometimes it gets stuck.
zonedoubt |
Oct 21 2009, 12:39 PM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
The light also comes on with master cylinder switch.
kenshapiro2002 |
Oct 21 2009, 12:56 PM
zonedoubt |
Oct 21 2009, 01:22 PM
Or maybe the M/C switch just needs resetting.
kenshapiro2002 |
Oct 21 2009, 02:16 PM
kenshapiro2002 |
Oct 22 2009, 09:19 AM
It's "fixed"...drove the piss out of the car, throwing her around corners with utter abandon. Noticed when I git home that I'd "fixed" the light issue. Now it;s only on when the e brake is up.
(IMG:style_emoticons/default/piratenanner.gif) |
VaccaRabite |
Oct 22 2009, 09:56 AM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
The italian tuneup fixes many things, but I did not know it worked for electrics too!
Zach |
charliew |
Oct 22 2009, 12:37 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
The fiero has a very similiar setup. After not using the ebrake for awhile the caliper and cable gets gummy and sometimes I have to put a heavy flashlight on the lever and drive awhile and it will finally settle back all the way down and depress the switch completely.
swl |
Oct 22 2009, 05:24 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
that is a switch to ground. If you have a nick or smush in the electrical lead it will leak to ground give you partial on. Spirited driving has moved whatever was pinching it. Betcha if you follow the cable you'll find it pinched somewhere - probably in the seat rail.
kenshapiro2002 |
Oct 22 2009, 05:25 PM
Probably right as it's now intermittent.
that is a switch to ground. If you have a nick or smush in the electrical lead it will leak to ground give you partial on. Spirited driving has moved whatever was pinching it. Betcha if you follow the cable you'll find it pinched somewhere - probably in the seat rail. |
kenshapiro2002 |
Oct 29 2009, 03:01 PM
Close...the contact consists of a metal point, trianguar in shape, that rests in a small hole when it makes contact. The switch was "nicked" a little and didn't always seat nicely. A Dremeling of the contact surfaces, some contact cleaner, and some WD40 on the mechanism got it all fixed.
Lo-Fi Version | Time is now: 2nd June 2024 - 07:47 PM |
