almost ready to install engine (now with pics), where does the brown wire go?? L-Jet |
jsayre914 |
Oct 29 2009, 10:09 AM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
where does the brown wire comming out of the loom right near the aar go? it has a single female spade connector on the end. the lable fell off this wire or i forgot to lable it. i dont see anywhere to connect it (IMG:style_emoticons/default/blink.gif)
i am so close (IMG:style_emoticons/default/piratenanner.gif) |
VaccaRabite |
Oct 29 2009, 10:14 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
attach everything else and see whats left. But Brown is usually a ground wire.
Usually. I bet that it grounds to the case. Find a 1.8 wire diagram in your haynes manual and trace it out. Zach |
7275914911 |
Oct 29 2009, 10:21 AM
Hummmm!!! Group: Members Posts: 756 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States |
IIRC
The LJet has a ground wire connection on case under plenum on passenger side. Seems like there are two ground wires that go here. I also had a single ground wire that went to the case up by the coil. This ground wire is still being used eventho I am now running 40idf's. Good Luck....another commonly overlooked wire is the resistor pack for the injectors on the 1.8 KP |
r_towle |
Oct 29 2009, 07:18 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Post a pic...I will go look.
Rich |
Dave_Darling |
Oct 29 2009, 09:51 PM
Is it actually brown, or is it white or yellow that is faded and dirty?
--DD |
Dr Evil |
Oct 29 2009, 10:23 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Pic
jsayre914 |
Oct 29 2009, 10:43 PM
pics (IMG:style_emoticons/default/biggrin.gif)
the wire is from the loom going to the black tester block thingy. not sure where this wire should go, not sure what the hell that black square thing is. i am learning as i go. (IMG:style_emoticons/default/screwy.gif) it is starting to look like an engine now Attached image(s) |
type47 |
Oct 30 2009, 02:14 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
Looks like that block is part of the connection to the dual relay.... You should check out the electrical schematic
7275914911 |
Oct 30 2009, 06:05 AM
pics (IMG:style_emoticons/default/biggrin.gif) the wire is from the loom going to the black tester block thingy. not sure where this wire should go, not sure what the hell that black square thing is. i am learning as i go. (IMG:style_emoticons/default/screwy.gif) it is starting to look like an engine now Brown wire in first pic is grounded by coil on my car. Second pic looks like half of the Duel Relay which is rear firewall in my car. Good Luck |
charliew |
Oct 30 2009, 12:47 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
On my 75-1.8 it is plugged on a tab that looks like part of the cooling shroud. It is visible looking in over the battery side back toward the tranny flange just barely out from under the intake plenum where the tubes hook on. There seems to also be a white wire also plugged on to a tab next to the brown wire.
jsayre914 |
Oct 30 2009, 03:05 PM
so i will attach it to ground. and we shall see.
on another note... can you hook the dual relay wrong, it seems the wire pinout on the left and the right are slightly different, and either way i plug them (only 2 ways) a wire in the pinout does not have a mate on the other slot. (IMG:style_emoticons/default/idea.gif) anyone got a pic. or can you tell if this is backwards? Attached image(s) |
Lo-Fi Version | Time is now: 5th June 2024 - 09:40 AM |
