2.0 fuel injectors, are aftermarket better than stock |
WFG |
Nov 1 2009, 07:22 PM
Newbie Group: Members Posts: 29 Joined: 6-December 05 From: nashville tenn 37076 Member No.: 5,243 |
just got my tranny back in my 914 after rebuild tranny works great but noticed annother prob 3 of 4 injectors were leaking from the body not the line thought i would replace all so i was wondering if aftermarket was better or worse than bosch
zymurgist |
Nov 1 2009, 07:34 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Leaking from the body? Are you sure about this? Seems like a high failure rate.
Did you use metric FI hose to connect them? 5/16" is almost 8mm, and you want 7mm hose for the injectors. |
WFG |
Nov 1 2009, 09:02 PM
Leaking from the body? Are you sure about this? Seems like a high failure rate. Did you use metric FI hose to connect them? 5/16" is almost 8mm, and you want 7mm hose for the injectors. not leaking from hose leaking at seam i have seen this happen on other bosch injectors when it is getting colder |
jsayre914 |
Nov 1 2009, 10:07 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
i recently sent 7 green top to cruzin for cleaning, to find only 3 of them not leaking (IMG:style_emoticons/default/sad.gif)
i sent a few more and finally got a set of 4 good ones. I am not sure if newer ones will run any better, but used ones are pretty cheap on this board. post an classified wanted ad and see what happens (IMG:style_emoticons/default/beerchug.gif) |
StratPlayer |
Nov 2 2009, 10:58 AM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
IMHO 30 yr, + injectors make me worry. I have stock injectors in the new engine that I just built. I see these threads about fires and it makes me worry even more. I'm getting ready to build another engine but this one will have new injectors in it.
I have a fire ext. in the cab of the car just in case. 30 yr + injectors can be a problem. |
Lo-Fi Version | Time is now: 23rd May 2024 - 05:21 PM |
