Transmission Question, Either the PO really greased these puppies, or I'm screwed |
knuckledrgr914 |
Nov 4 2009, 01:29 PM
Newbie Group: Members Posts: 46 Joined: 17-June 08 From: Meridian Member No.: 9,180 Region Association: None |
I was dropping the motor and trani in my '74 1.8l to try and locate a very large oil leak. I guess the leak isn't so bad since it only happens when the car is running (IMG:style_emoticons/default/happy11.gif)
When taking out the bolt from the transaxle, they came out dripping with oil. Besides the obvious, being totally screwed, I need some advise as to where to even begin. Maybe I will just cut my losses and run... Brad |
EdwardBlume |
Nov 4 2009, 01:32 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
Are you sure that's not just old grease? Mine look that bad and hold up just fine.
SirAndy |
Nov 4 2009, 01:35 PM
Resident German Group: Admin Posts: 41,658 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
That CV does not look right ... (IMG:style_emoticons/default/unsure.gif)
knuckledrgr914 |
Nov 4 2009, 01:50 PM
knuckledrgr914 |
Nov 4 2009, 01:52 PM
Thanks SirAndy. What do you think looks wrong? Brad |
SirAndy |
Nov 4 2009, 02:05 PM
Thanks SirAndy. What do you think looks wrong? It looks like the shaft has pulled out of the CV. Look at the angle of the shaft compared to the center of the CV ... Pull off that rubber boot and show us what's inside. (IMG:style_emoticons/default/idea.gif) Andy |
knuckledrgr914 |
Nov 4 2009, 02:37 PM
Thanks SirAndy. What do you think looks wrong? It looks like the shaft has pulled out of the CV. Look at the angle of the shaft compared to the center of the CV ... Pull off that rubber boot and show us what's inside. (IMG:style_emoticons/default/idea.gif) Andy Will do. I have to head out now and will try to get back to it tonight. Thanks, Brad |
detoxcowboy |
Nov 4 2009, 05:04 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
I think Andy Pegged it!! CV is Out of line, I had grease somewhat like you across the bottom of starter amoung other places and it was the boot only but when I repacked with grease I found out how tricky they are to fit back together correctly, I fitted one together (did all four) and it went togther but was stiff and ackward, not right..., there is only one way so maybe thats the issue, don't give up ever. When it gets hard is when you learn, and when you learn you save $$$ because now you can do it yourself.. Worth the effort..
jcd914 |
Nov 4 2009, 07:16 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Looks to me like the engine/trans is sitting on a jack and has been lowered down part way out of the car. That would be about the only explanation for the upward angle of the axle.
I have seen many where someone has packed new grease into a CV joint and filled the bolt holes in the process. Jim |
Lo-Fi Version | Time is now: 28th May 2024 - 01:15 PM |
