> emergency lights stopped working.., after about 5 flashes.. ??
SECHSER
post Nov 4 2009, 08:39 PM
k, so i have a feeling this might not be that big of a deal.. after all i thought it was just gonna be a bad flasher relay, but then i discovered that it worked again after i disconnected and reconnected the battery. well, for 5 more flashes.. so this is just totally weird.. (IMG:style_emoticons/default/dry.gif)
anyone's got this kinda issue? could this still be a bad flasher relay? thanks in advance.
underthetire
post Nov 4 2009, 09:10 PM
I had an old Datsun pickup that did that. It was the flasher relay on it. Replaced it and it burnt out agin. apparently on that truck if the hazzards were on and you pressed the brake pedal, things went very wrong.
detoxcowboy
post Nov 4 2009, 09:32 PM
Region Association: Africa
I would start with a new relay, sound as electrically it is dis functional after a few clicks, it is by the way the most active hard use relay.. I have had a few differnt electrical items fail that way work for a little then seize/stop unplug it re-start it and agin works for 5 seconds then nada..
Cap'n Krusty
post Nov 5 2009, 12:40 AM
Cap'n Krusty
Work the hazard switch about 20 cycles to clean the contacts and see if that helps. The Cap'n
- Lo-Fi Version Time is now: 12th July 2025 - 08:45 AM
