Need help with ground control coilover kit, searched forum but can't find answers |
vintage914racer |
Nov 17 2009, 08:51 AM
Member Group: Members Posts: 429 Joined: 28-December 03 From: Minneapolis, MN Member No.: 1,473 |
Good morning. I'm having problems getting my questions answered so I figured I would post it here.
As anticipated my ground control coilover kit arrived today and I have questions listed below. 1. The hole in the upper spring perch is not large enough for the top of the shock. Can I simply drill the hole out or should I complain to ground control? I'm anxious to get these installed on the car, but realistically I won't be able to do anything with the car until next spring anyway 2. At what notch should I put the circlip on my Bilstein sports? In the past I've read to put it on the second notch, does this seem correct I'm having a problem posting pictures. |
SirAndy |
Nov 17 2009, 11:46 AM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I'm confused.
Do you mean the threaded collar does not slide over the shock? They come in different sizes for different brands of shocks. Or are you talking about the top piece that goes on top of the spring? I have a ground control kit with Koni shocks and everything was a good, tight fit. (IMG:style_emoticons/default/idea.gif) Andy |
vintage914racer |
Nov 17 2009, 02:46 PM
The threaded collar fits fine. I am having issues with the top hat that goes on top of the spring. There is a stepped hole for the very top of shock that is not large enough. I already called GC and they were a bit confused. I'm sending them detailed pictures to better explain the issue.
Lo-Fi Version | Time is now: 9th June 2024 - 09:27 PM |
