Koni Adjustable Spring Perch and Spring Size, What is the diff between stock and adj? |
Zeke |
Apr 3 2003, 07:43 PM
Never left, but not right.... Group: Members Posts: 381 Joined: 26-January 03 From: Long Beach CA Member No.: 197 Region Association: None |
I have Konis on the rear. I want to add the adjustable threaded collar kits. I have to buy smaller diameter springs? What is the diameter of the spring that goes with the kit? If so, I have #160's and #180's for sale.
Jeroen |
Apr 3 2003, 08:00 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
IIRC the most used the inner diameter of the springs is 2.5"
anyone know what length to get? 8" or 10" or....??? cheers, Jeroen |
drew365 |
Apr 3 2003, 08:02 PM
These are the good old days! Group: Members Posts: 2,004 Joined: 29-December 02 From: Sunny So. Cal. Member No.: 37 |
The perchs on my Bilsteins accept 2.5" springs. I'm pretty sure the Koni's are the same. Hoerr racing has a catalog that lists 2.5" Hypercoil springs at every length and size for a reasonable price. I have a pair of Eibech and a pair of Hypercoil. The Hypercoil has a much larger coil and seem better made.
vortrex |
Apr 3 2003, 08:05 PM
Senior Member Group: Members Posts: 1,687 Joined: 24-December 02 From: SF, CA Member No.: 4 Region Association: None |
the springs I have for my koni adjustable coilover kit are 10".
drew365 |
Apr 3 2003, 08:10 PM
My Eibach's are 10" and leave plenty of adjustment in both directions. My Hypercoils are 12" and sit pretty far down on the perch. I'd recommend 10" all other things being equal.
ChrisReale |
Apr 3 2003, 08:11 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
anybody have a pic of one of these set-ups?
Zeke |
Apr 3 2003, 08:29 PM
We need to be talking about diameter. Height is a moot point if you have adjustable perches.
Man, 2.5 inches is a skinny ass spring! Must hug the dust cover pretty tight. |
vortrex |
Apr 3 2003, 08:31 PM
mine is larger than 2.5 inches, hang on...
vortrex |
Apr 3 2003, 08:32 PM
the outer edge to outer edge diameter is 3.25".
the inner edge to inner edge is 2.5". |
Joseph Mills |
Apr 3 2003, 08:47 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
Same here. 10" length
3.25" OD the coil wire is approx. 3/8". Mine are supposed to be 160#. Zeke - plenty of room for the shocks. |
Zeke |
Apr 3 2003, 08:49 PM
Vortex and Joesph, you have these on threaded adjustable collars, right? That was the original question, what spring for the collars.
vortrex |
Apr 3 2003, 09:01 PM
yes sir I do.
Joseph Mills |
Apr 3 2003, 09:31 PM
QUOTE(vortrex @ Apr 3 2003, 09:01 PM) yes sir I do. -same- (IMG:style_emoticons/default/driving.gif) threaded adjustable collars (IMG:style_emoticons/default/driving.gif) |
seanery |
Apr 3 2003, 10:22 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I have them too, 2.5 inside diameter. Got the whole kit from Performance Products.
Brad Roberts |
Apr 4 2003, 01:36 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Milt:
10 inch 2.5 I use Eibach and H&R. Call Jason@ Paragon Products. Tell him your with the 914 club and Brad said we get a discount... |
Zeke |
Apr 4 2003, 11:37 AM
QUOTE(Brad Roberts @ Apr 3 2003, 11:36 PM) Milt: 10 inch 2.5 I use Eibach and H&R. Call Jason@ Paragon Products. Tell him your with the 914 club and Brad said we get a discount... This is starting to get difficult. I have Koni streets on the rear which were destined to get revalved. I can see that the collar kit is not compatable for the Koni street shock. What shocks should I be using? And what are those in the pic? TIA. |
vortrex |
Apr 4 2003, 11:45 AM
I have the koni reds with my kit, which I guess is what you mean by "street" shocks?
Brad Roberts |
Apr 4 2003, 12:01 PM
The kit a I showed will work, but you'll have to run a 8 inch spring. The one pictured above is a Bilstein (which is a what I use when a customer wont pop for Koni adjustables.
You have the old red Koni's with the solid base (correct ?) They used a thick piece of plastic that you cut to get the ride height. If your going to have them revalved.... dont be afraid to cut that collar off and move it where you want. B |
seanery |
Apr 4 2003, 12:02 PM
I have koni yellows.
Mueller |
Apr 4 2003, 12:43 PM
Left to right:
Koni Regular (for sale) Bilstein Gas (for sale) and Koni Sports (going on the car) You can see the difference in the location for the spring perches. |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:03 PM |
