Novice question about struts |
RonnieJ |
Nov 27 2009, 05:02 PM
RonnieJ Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest |
I've done a search but cannot find anything on how to remove old and install new strut inserts on my 914. Is there instructions on here somewhere or can somone explain how. Thanks
type47 |
Nov 27 2009, 06:05 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
I believe that the workshop manual instructs to remove the strut to replace the insert. I put my car up on stands after removing the wheel, disconnected the top of the strut and was able to move the top out of the wheel well to get access to the insert. There is a threaded cap that is removed to get to the insert. After replacing the insert, assembly was the reverse.
RonnieJ |
Nov 27 2009, 06:11 PM
I believe that the workshop manual instructs to remove the strut to replace the insert. I put my car up on stands after removing the wheel, disconnected the top of the strut and was able to move the top out of the wheel well to get access to the insert. There is a threaded cap that is removed to get to the insert. After replacing the insert, assembly was the reverse. Thanks Type47 I'll give it a shot tomorrow. |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:11 PM |
