jsayre914 |
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,210 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region ![]() |
I bought an Optima Yellow Top about a year ago. It was fairly cheap and still works well. I have been fine tuning my stereo system, wich has a totall of about 700 watts at peak performance. My headlights are still dimming on the higher volume. I have capacitorrs installed next to each amp, but the battery is just not big enough.
My yellow top is rated at 870 amps. The kinetik is rated at 1900 amps. My plan was to install the kinetik hc1800 to replace the yellow top, it is the same size and weighs 54lbs, a little bit heavier than the optima. (not much) Then I was going to replace both capacitors with an hc800 mounted next to the amps in the trunk. (IMG:style_emoticons/default/happy11.gif) Anybody have experience with 2 battery setup in a 914?? the site http://www.kinetikaudio.com/2009/default.asp |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
you need an alternator that can keep up with the max draw that your system is capable of drawing. that is the only way to keep the lights from dimming.
what you pull out needs to be put in. caps don't work, it's a gimmick, the wrong use for a cap. |
turboturtle |
Member ![]() ![]() Group: Members Posts: 56 Joined: 19-February 09 From: Little Rock, Arkansas Member No.: 10,068 Region Association: None ![]() |
Yup, as Messix above posted. I just checked Kinetics web site and they say exactly the same thing in all their battery descriptions. The alternator is the key to keeping the power going. Mean Green alternators are the bomb.
Bob |
Cupomeat |
missing my NY 914 in VA ![]() ![]() ![]() Group: Members Posts: 1,338 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region ![]() |
Does Mean-Green make an alternator for a T2/T4 Application?
I can't seem to find one. (IMG:style_emoticons/default/WTF.gif) The site does not list that they have one that would fit our application. As my alternator is dying I am looking to a slightly bigger replacement, any suggestions that I can buy? (IMG:style_emoticons/default/popcorn[1].gif) |
Dr Evil |
There are alternators that are sold by a member here that are 100amp units made out of the stock low amp units.
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
You can also get a later bus unit. think they were 70 amp.
http://shop.oreillyauto.com/ProductDetail....=11&PTSet=A |
jsayre914 |
As my alternator is dying I am looking to a slightly bigger replacement, any suggestions that I can buy? (IMG:style_emoticons/default/popcorn[1].gif) I just googled it and found a nice 220 amp replacment as opposed to our 55 amp stock. (if it fits) ![]() Holy Shit! http://powerbastards.com/proddetail.asp?prod=Fitzall%2D220 |
peetzinc |
peetzinc ![]() ![]() Group: Members Posts: 60 Joined: 30-November 07 From: Salem, Oregon Member No.: 8,396 Region Association: None ![]() |
Seems like a lot of work and $ to listen to music. I kinda like the sound of my webers sucking air!
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,282 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
I have been fine tuning my stereo system, wich has a totall of about 700 watts at peak performance. (IMG:style_emoticons/default/biggrin.gif) Andy |
Dr Evil |
Joe, the higher the wattage of the Alt the more horse power it will drain from your 1.8. You will be going slow listening to tunes. So what you should do is pick an alternator that will slow your car down enough for you to hear the radio but will keep your lights from dimming (IMG:style_emoticons/default/rolleyes.gif)
Dr Evil |
As I said before, one of the vendors here has 75 and 90 amp stock fit alternators:
http://www.914world.com/bbs2/index.php?sho...;hl=alternators |
jsayre914 |
As I said before, one of the vendors here has 75 and 90 amp stock fit alternators: http://www.914world.com/bbs2/index.php?sho...;hl=alternators pm sent (IMG:style_emoticons/default/slap.gif) |
jsayre914 |
I set the Kinetik in place of the yellow top, WOW. I have not hooked it up yet, still waiting on a few wires, just wanted to check the fit. The rain tray needed a slight modification to close (IMG:style_emoticons/default/rolleyes.gif)
What do you think about placment of the second battery, it is not heavy at all, so I made a tray, and hinged a tray under it for the relay to sit at a 45 angle, that way i dont need to move any wiring. (IMG:style_emoticons/default/aktion035.gif) Attached image(s) ![]() ![]() ![]() ![]() ![]() |
underthetire |
Cool ammo can lid !
SirAndy |
What do you think I think you need to clean that damn engine bay! (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/FERG.gif) |
Dr Evil |
shoe horn
jsayre914 |
Lo-Fi Version | Time is now: 31st July 2025 - 06:19 PM |
