My numbers are Whack !$%? |
jsayre914 |
Dec 1 2009, 11:00 AM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
Car is running great, still chirps a little, but no problems. 1.8 L w/ L-jet took off the heads and cleaned them up. New stock mm pistons and cylenders. New head gaskets, intake gaskets runner boots all fuel lines replaced all vacume hose replaced. Fuel injectors cleaned (cruzin) new fuel filter air filtre, new plugs and wires. Pertronix.Set valves ETC. ETC.
so 4 weeks later (today) I do a compression test. Car was warmed up, battery fully charged, pulled all plugs and held down gas pedal..... 1. 90 2. 110 3. 100 4. 120 I checked 2 times (IMG:style_emoticons/default/confused24.gif) |
jsayre914 |
Dec 1 2009, 11:11 AM
here are the plugs if yr interested..
Attached image(s) |
VaccaRabite |
Dec 1 2009, 11:17 AM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Not possible, unless your cylinders were out of round, your rings have not seated or you have some sort of massive head leak. You are doing something wrong.
Try this. When the engine is dead cold, adjust your valves. Get the engine warm and find a quiet road. From rolling in second, stomp the gas and take it up to redline. Lift off and let the car coast back down to rolling idle, and do this routine twice more. Thats what Jake says to do to seat the rings. When you get back home, check your chamber pressure again. Zach |
VaccaRabite |
Dec 1 2009, 11:22 AM
Also, unless you have pulled the plugs out whlie the car was hot under load, Rich and Jake have both advised me the reading plugs is useless. You are just reading them at idle, not under load.
From MD going north up 83, hitt the ramp to the rest stop just before exit 4, and shut down the motor and coast up the ramp to stop. That way you won't have ANY idle messing thing up when you pull the plugs to read them. That said, 1, 2, 4 look rich to me. Zach |
Dr Evil |
Dec 1 2009, 11:28 AM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Gee, did someone say your rings not seated?
SirAndy |
Dec 1 2009, 12:08 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
You are just reading them at idle, not under load. (IMG:style_emoticons/default/agree.gif) Back in my dirt bike racing days, we would cut the ignition (panic button) under full throttle, then stop and check the plugs. Anything other than load won't give you any good plug readings ... (IMG:style_emoticons/default/shades.gif) Andy |
yeahmag |
Dec 1 2009, 12:12 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
If it's chirping, especially when cold, you have a leak at the head to cylinder sealing surface.
tat2dphreak |
Dec 1 2009, 12:23 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
when did you put the new P/Cs in?
I just don't think your engine is seated yet (IMG:style_emoticons/default/smile.gif) 4 weeks? did you put 1500 miles on in those 4 weeks? 1000? |
VaccaRabite |
Dec 1 2009, 03:14 PM
If Joe has been DDing the car every day, he probably has ~1500 miles on it now. His commute is ~100 miles (a day, not one way)
Zach |
jsayre914 |
Dec 1 2009, 03:27 PM
at least 1500 miles since i put them on there
tat2dphreak |
Dec 1 2009, 03:29 PM
hmm, time to bust out the borax (IMG:style_emoticons/default/biggrin.gif)
Mark Henry |
Dec 1 2009, 03:30 PM
Head gasket.
Chirping is a dead give away, disconect the ignition crank away (cold) and listen for a whistle/squeaking noise from the lean cylinder. |
VaccaRabite |
Dec 1 2009, 03:33 PM
Joe, come over. We can hit it with the leak down tester and find out if its leaking from the head. I'm home tonight and free (but may take a nap if I don't hear from you).
Zach |
tat2dphreak |
Dec 1 2009, 03:36 PM
Head gasket. Chirping is a dead give away, disconect the ignition crank away (cold) and listen for a whistle/squeaking noise from the lean cylinder. damn I totally missed that!! that was the dead giveaway on mine too, every cylinder was leaking because the cylinder didn't fit into the head squarely... on mine the heads were not cut straight |
Dr Evil |
Dec 1 2009, 04:08 PM
I would have suspected as much. I told Joe just to get another used p/c so as to not mess up the (dis)harmony of his tired 1.8. He had to go and buy new ones. And then he did not break them in (IMG:style_emoticons/default/dry.gif) I bet this is the cylinder that had the messed up piston originally. I bet the head and the register are kaka. He should stop throwing money at that low HP POS and put money into his 2056 instead (IMG:style_emoticons/default/rolleyes.gif) Those p/c were $300 that could have gone to cams, lifter sets, 2056 p/c, etc..... Joe is unusual (IMG:style_emoticons/default/wink.gif)
Mark Henry |
Dec 1 2009, 04:27 PM
I would have suspected as much. I told Joe just to get another used p/c so as to not mess up the (dis)harmony of his tired 1.8. He had to go and buy new ones. And then he did not break them in (IMG:style_emoticons/default/dry.gif) I bet this is the cylinder that had the messed up piston originally. I bet the head and the register are kaka. He should stop throwing money at that low HP POS and put money into his 2056 instead (IMG:style_emoticons/default/rolleyes.gif) Those p/c were $300 that could have gone to cams, lifter sets, 2056 p/c, etc..... Joe is unusual (IMG:style_emoticons/default/wink.gif) I have some nice parts for sale....I know....shameless plug .... |
SirAndy |
Dec 1 2009, 04:30 PM
r_towle |
Dec 1 2009, 07:29 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I would have suspected as much. I told Joe just to get another used p/c so as to not mess up the (dis)harmony of his tired 1.8. He had to go and buy new ones. And then he did not break them in (IMG:style_emoticons/default/dry.gif) I bet this is the cylinder that had the messed up piston originally. I bet the head and the register are kaka. He should stop throwing money at that low HP POS and put money into his 2056 instead (IMG:style_emoticons/default/rolleyes.gif) Those p/c were $300 that could have gone to cams, lifter sets, 2056 p/c, etc..... Joe is unusual (IMG:style_emoticons/default/wink.gif) I have some nice parts for sale....I know....shameless plug .... Like what? Rich |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:29 PM |
