nebreitling |
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 ![]() |
when i throw the car into moderately long, hard, and sustained turns, the engine feels like it is starved for fuel. it will never die, simply it loses almost all power until i straighten out.
what i've done: -checked timing (fine) -fuel pressure at 30 psi -new fuel filter obviously, i can't check the fuel pressure while turning (actually, maybe that's not so obvious. i could probably rig a hose into the cockpit....) -- it just feels like fuel starvation.. any ideas? thanks, nathan ps car is a 75 2.0 (Djet) btw, i'm open to the possibility that this may not be a fuel delivery problem, but i recently went through the ignition system, installed a crane xr700, cleaned up grounds, new FI points, etc. |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,338 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Is this a new problem since you upgraded the ignition system?
nebreitling |
good question. the answer is:
i don't know. i upgraded the ignition and changed the FI trigger points at the same time because the car started running horribly. now it runs like a champ in a straight line, coughs in the corners. |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
Maybe something in the tank? Low oil pressure? Bad ground on fuel pump? Loose wire on Ign?
???? (IMG:style_emoticons/default/confused24.gif) Jeff |
nebreitling |
okay, it's not a dip in fuel pressure that's causing this. (you do NOT want to know what i just did to check this (IMG:style_emoticons/default/cool.gif) ). checked the grounds and relays and such. ditto on the fuel pump ground. all good, didn't fix the prob. tank is totally clean, the fuel filter i replaced today was spotless when i cut it open. no hoses kinked...
i'm gonna pull that rat's nest i call my FI harness and clean it up. i'll get to the bottom of it yet.. |
Bruce Allert |
Hellions asleep ![]() ![]() ![]() ![]() Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest ![]() |
QUOTE(nebreitling @ Mar 19 2004, 04:06 PM) when i throw the car into moderately long, hard, and sustained turns, btw, i'm open to the possibility that this may not be a fuel delivery problem, So, it's both, right & left turns? .......b |
nebreitling |
WELL, as of my last test drive, i can only replicate the effect in a left turn. which, to my probably-over-simplistic understanding of things, suggests that i should look for connections that may be getting loose given inertia to the right. (total shadetree, here)
also, i was able to replicate it in a parking lot with a sustained loop (again, to the left). after feeling it for a while, it feels more like one cylinder is missing... this also explains why it will never stall. i'm about to go back outside and check the FI connections... |
TheCabinetmaker |
Nathan, I know this sounds crazy, but, have you checked the air filter? A clogged one drove me nuts for a few months. going up hill,just die, turning right, just die. replaced filter, no more just die.
Curt |
nebreitling |
hell, nothing's too crazy in troubleshooting. that's not it, though, just replaced the air filter... (K+N baby! that atleast good for another 0.45 hp!)
TheCabinetmaker |
QUOTE(nebreitling @ Mar 19 2004, 07:52 PM) (K+N baby! that atleast good for another 0.45 hp!) LMAO (IMG:style_emoticons/default/laugh.gif) |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,234 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
cylinder head temp sensor is loose (or the connector to it) ... (IMG:style_emoticons/default/wink.gif)
Bruce Allert |
(IMG:style_emoticons/default/agree.gif) w/ Andy
OR... check the connection to the AAR. If that's getting a "slight" short (slight or intermittant exposure of a bare connector/wire) it can give problems with power loss as it vibrates or moves across an area. .......b |
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
what kind of turn? A sustained high speed turn? Is this a new problem? If it is only in sustained high speed turns, possibly it is a reduction or loss of oil pressure due to the oil running away from the pick-up tube. Do you hae a "deep sump" or anything special at the pick-up?
Are all your fuel hoses anchored enough to keep them from kinking under turning conditions? Could the fuel line (rubber hose) kink only when turning? Could a line be being pinched by the steering rack or the sway-bar as the car is turned? (I had one that had a fuel line pinched between the bottom of the tank and the top of the sway bar and drove me nuts for about a day while I searched for the problem...... I wish you the best of luck in finding your problem. Johnman |
nebreitling |
FOUND IT!! (IMG:style_emoticons/default/smilie_pokal.gif)
f-ckedup connection to the #4 injector. did a quick fix, still need to pull the harness and give it a little, errr, 'refreshing'. my car now goes like rush limbaugh in an oxycontin factory. except it's a lot lighter, and turns sharper. power oversteer!!! woo hooo!!! (IMG:style_emoticons/default/burnout.gif) |
Bruce Allert |
Good Job, (IMG:style_emoticons/default/beer.gif) Good sleuthing.... (IMG:style_emoticons/default/smash.gif) now go fix sumpin else! (IMG:style_emoticons/default/smilie_pokal.gif)
.........b |
Lo-Fi Version | Time is now: 1st July 2025 - 11:09 AM |
