Sticky Stuff Removal, removed engine bay sound barrier! |
Bruce Allert |
Mar 21 2004, 07:36 AM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
What can I use to take off the sticky stuff & ugly black crap that held the backpad to the firewall? Is there anything that won't get me off (IMG:style_emoticons/default/wacko.gif) If not I'd like to use some good shit & just be done wit it (IMG:style_emoticons/default/wink.gif)
..........b P.s. NO RUST IN THE HELL HOLE!! (IMG:style_emoticons/default/boldblue.gif) Woohoo (IMG:style_emoticons/default/beer.gif) |
Bleyseng |
Mar 21 2004, 08:41 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
laquer thinner works pretty well although the fumes are killer. Wear a mask
TheCabinetmaker |
Mar 21 2004, 08:45 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Bruce, I thought you'd have that 2 litre in by now? (IMG:style_emoticons/default/laugh.gif)
Just kidding, lacquer thinner should do the job. |
John2kx |
Mar 21 2004, 10:17 AM
Senior Member Group: Members Posts: 502 Joined: 22-August 03 From: Augusta, Ga. Member No.: 1,066 |
Bruce,
This was the worst part of any area on my car to restore. Tried paint remover, sanding, scraping, wire wheels and just about everything else I had in shop to remove factory and PO installed glue. Since my car is black, I would have had to put more effort than I did to end up with a surface finish equal to the exterior. After spending countless weekends on my back, knees or bent over engine bay, I settled by spraying entire engine bay with one of the truckbed liner type coatings. It turned out OK but not as easy to keep clean as a smooth paint finish would have. The rougher coating I chose seems to collect anything that comes in contact with it. Just another case of "90% prep". Have you considered sand blasting? John |
boxstr |
Mar 21 2004, 10:26 AM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
Bruce we could tow dolly the car out to OC and have it media blasted. Ledt me know.
CCLINBLASTERBAY |
rhodyguy |
Mar 21 2004, 10:33 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
gumout carb cleaner worked the best for me. let it work a bit and the glue will roll up like snot balls. not a paper mask either. go to home depot and get one rated for vapors with the screw on canisters. you'll need it to paint anyways.
kevin |
McMark |
TA-DA!
1001 uses for Berryman's Brake Cleaner! It'll take you about 4 hours total and will remove the original paint, but it'll be gone and you can then repaint it. Make sure your garage door is open. Fumes aren't as bad a laquer thinner though. Note: Berrymans! (IMG:style_emoticons/default/beerchug.gif) |
jd74914 |
Mar 21 2004, 10:49 AM
Its alive Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
You could always try the "poorman's method."
Worked fine for me. (IMG:style_emoticons/default/happy11.gif) Attached image(s) |
jd74914 |
Mar 21 2004, 10:51 AM
Attached image(s) |
TheCabinetmaker |
Mar 21 2004, 11:01 AM
Uh, those are "wood" chisels. I just pulled a 1.7 last week that had the worst oil leak ever. The blanket had been removed a few years ago and there was about a half inch of oil builup on the fire wall. A good stiff 1 1/2" putty knife with the corners rounded off (keeps ya from digging into the metal) worked like a champ. the glue had been soften by the oil and came right off. So, all you need is a good oil leak (IMG:style_emoticons/default/laugh.gif)
Qarl |
Mar 21 2004, 11:06 AM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
My wife says there is something called unisolve, that is skin-safe that dissolves adhesives.... (designed to remove bandage and tape residue).
Maybe that would work? |
jd74914 |
Mar 21 2004, 11:08 AM
QUOTE Uh, those are "wood" chisels. Yeah, I know it. (I build cabinets in my spare time). Though, the chisel I used was dull as a hoe and so screwed up I figured it wasn't worth trying to fix it for the 1000th time. QUOTE A good stiff 1 1/2" putty knife with the corners rounded off (keeps ya from digging into the metal) worked like a champ. You only need to be gentle to avoid killing the metal (as chisels slice through it like butter) (IMG:style_emoticons/default/beerchug.gif) BTW I didn't actually take a pic of my tools (these are from google images) |
TheCabinetmaker |
Mar 21 2004, 11:10 AM
Cool, I build them for a living, and fix 914's in my spare time (IMG:style_emoticons/default/rolleyes.gif)
jd74914 |
Mar 21 2004, 12:21 PM
(IMG:style_emoticons/default/smilie_pokal.gif) Way to be (IMG:style_emoticons/default/beerchug.gif)
McMark |
Mar 21 2004, 01:06 PM
Wood chisels and heat work great for removing undercoating from the wheel wells and under the car.
Jenny |
Mar 21 2004, 01:35 PM
Advanced Member Group: Members Posts: 4,060 Joined: 6-January 03 Member No.: 96 Region Association: None |
I second the brake cleaner method. From Brad's school of automotive. Works great. Have a fan nearby circulating air though. I remember getting pretty loopy working in the engine bays. I removed that shit from both the orange and silver cars.
Jen |
Bruce Allert |
Mar 21 2004, 04:22 PM
Everyone had great suggestions (IMG:style_emoticons/default/smilie_pokal.gif) Thanks!
Curt, I know I should'a had it back in by now but, I'm sure you know, as you're working on one thing on the car, another catches your eye & it's off on a different tangent until you get re-directed back to what you originally started! I got the tranny off the 1.7 yesterday & cleaned it up. Raised the car another 4 or 5 inches, pulled the blanket off the back then removed the motor mounts off the 1.7 to use them on the 2.0 since thay are almost brand new. Must have a wee bit of Attention Defficet going on (IMG:style_emoticons/default/laugh.gif) Wanted to stay home this morning & put the tranny on the 2.0 but my boss called & said they needed a 4th for a scramble... (& if I didn't attend & was fired)! (IMG:style_emoticons/default/rolleyes.gif) So, after 18 holes & a couple beers........... Craig, thanks for the offer but I don't really wanna go that far since I have the car up on blocks. After I see if this 2.0 runs then I will consider taking it back out & do a total clean up of that part of the car & engine. Thanks again for everyones help (IMG:style_emoticons/default/beerchug.gif) ........b |
TheCabinetmaker |
Mar 21 2004, 04:34 PM
See? You're already talking about pulling it out again.
The more ya do it the easier it gets. My son in law have done 5 together now. Out and back in. We pulled one two weeks ago in 25 minutes. He did the top while I was underneath. |
bernbomb914 |
Mar 21 2004, 05:03 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
There is a foil insulation pad listed on ebay which will cover that mess and give you some sound deadening. It is cut to fit perfectly.
Bernie |
Bruce Allert |
Mar 21 2004, 06:56 PM
QUOTE(vsg914 @ Mar 21 2004, 03:34 PM) See? You're already talking about pulling it out again. The more ya do it the easier it gets. Ya, Ya... I'm already looking forward to the install & another removal (IMG:style_emoticons/default/beer.gif) When you have the moves down pat & the way you lift the car it really ain't that bad. I think I just might buy an RV lift like the one I borrowed from JP. I also want to get a "C" or "I" beam that will catch under the control arms. The beam would rest on the RV jack. With the wide table area of the RV jack (2'x2') it makes a sturdy way to lift the rearend. Bernie, I was thinking along those lines just so I wouldn't have to scrape all that crap (IMG:style_emoticons/default/rolleyes.gif) It would seem to add light or brightness to the bay too. Gotta check it out. .....b |
Lo-Fi Version | Time is now: 9th June 2024 - 04:03 PM |
