Photo/Info Request, Need Some Help With Heat/Fresh Air Bowden Cables |
kconway |
Jan 27 2010, 06:28 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
My car did not have the "normal" dash fresh air/heat controls since the PO Gerry rigged something in it's place. Can someone please photograph or provide a photo of the flapper boxes and the cables connections inside the front trunk area so I can hook mine up correctly.
I'd be extremely grateful. (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/grouphug.gif) (IMG:style_emoticons/default/pray.gif) Kev |
detoxcowboy |
Jan 27 2010, 06:33 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
I cant photo but that was a pita, and in the end i cross check everything but much later i found out my driver side defrost is reveresed to the fan so when the fan is on, the vent is closed aaaargh!! just check every scenario when your done cause it is hard or even close to impossible with the gas tank in.. unless you have slim hands and fingers that are spiderman strong..
jim_hoyland |
Jan 27 2010, 06:39 PM
Get that VIN ? Group: Members Posts: 9,327 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
If you look very closely. the Haynes Manual has a pic and explanation. Your welcome to come down and check out mine...
kconway |
Jan 27 2010, 06:40 PM
I cant photo but that was a pita, and in the end i cross check everything but much later i found out my driver side defrost is reveresed to the fan so when the fan is on, the vent is closed aaaargh!! just check every scenario when your done cause it is hard or even close to impossible with the gas tank in.. unless you have slim hands and fingers that are spiderman strong.. Tank is out as well as the airbox, but I've heard its a bitch to get connected. Perhaps without the tank and airbox its a managable job? (IMG:style_emoticons/default/idea.gif) |
championgt1 |
Jan 27 2010, 09:40 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
Everything you need to know is right here. The good stuff starts at post #7 (IMG:style_emoticons/default/beerchug.gif)
http://www.914world.com/bbs2/index.php?showtopic=86942 |
Lo-Fi Version | Time is now: 16th June 2024 - 03:05 AM |
