Muffler Bracket Hangers?, Heat Exchanger does not line up? |
Vysoc |
Jan 31 2010, 01:15 PM
Vysoc Group: Members Posts: 586 Joined: 27-August 09 From: Young Harris, Georgia Member No.: 10,737 Region Association: South East States |
Hello, I am hoping this is a fairly straight forward situation with a hanger that I do not have or just a simple fabrication of a couple of additional brackets. Last night while attempting to watch the 24 Hours of Daytona, we were installing my Stainless Heat Exchangers, several of the original Exhaust studs were broken and replaced but several were slightly offset when they were reinstalled. It was really a PIA getting things bolted back up due to the obvious clearance issues with the exhaust bolts. So when fitting up the muffler bracket on the transmission things are off as you can see in the pictures, heat exchangers hang down about 2 inches. Am I missing a hanger or should I just fabricate a couple of pieces of steel. The actual muffler lines up just fine to the six holes.
Thank you, Vysoc (IMG:style_emoticons/default/sawzall-smiley.gif) |
SirAndy |
Jan 31 2010, 01:20 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
heat exchangers hang down about 2 inches What size engine? Those look like 2.0L exchangers. The 1.7L/1.8L have a bend and go up about 2" ... You'll need a 2.0L muffler hanger for those. If your muffler is a 1.7/1.8, it'll sit way too low with those, you'll have to get a 2.0L muffler as well. (IMG:style_emoticons/default/shades.gif) Andy |
Vysoc |
Jan 31 2010, 02:58 PM
Engine is a 73 GA 2.0, I am replacing my 75 GC 2.0, Muffler Hanger is from the original 75 GC 2.0. Will the lower position cause interference with anything? Thanks, Vysoc |
SirAndy |
Jan 31 2010, 03:05 PM
Engine is a 73 GA 2.0, I am replacing my 75 GC 2.0, Muffler Hanger is from the original 75 GC 2.0. Will the lower position cause interference with anything? The '75/'76 exchangers and mufflers are a completely different system. When backdating, you need to get an early 2.0L hanger. And you should get an early 2.0L muffler to match the new setup. (IMG:style_emoticons/default/shades.gif) Andy |
Lo-Fi Version | Time is now: 7th June 2024 - 09:37 AM |
