now i'm really fuched |
underthetire |
Feb 17 2010, 09:18 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Broke off two head studs pulling the old heat boxes to put on my header. (IMG:style_emoticons/default/headbang.gif)
Do i drill them out and try to get something to fit or just start on my GA rebuild? Was planning on driving the car while i did it, but... BTW this motor will be scraped since it's a bus 2.0 once the real engine is done. |
McMark |
Feb 17 2010, 09:30 PM
I assume you're talking about exhaust studs. Is there anything left of them sticking out? Welding a nut onto the end can help, also careful application of heat to the aluminum boss can help the broken stud come out.
Drilling is very risky. I've done it a few times successfully, but it's not easy and it takes a lot of skill in being able to estimate angles and depth. If you go too deep you'll break into your exhaust port. If you go in at the wrong angle, your exhaust won't go on. A slight misalignment at the head, becomes a large misalignment at the end of the new stud. Good luck. (IMG:style_emoticons/default/sad.gif) |
underthetire |
Feb 17 2010, 09:36 PM
I assume you're talking about exhaust studs. Is there anything left of them sticking out? Welding a nut onto the end can help, also careful application of heat to the aluminum boss can help the broken stud come out. Drilling is very risky. I've done it a few times successfully, but it's not easy and it takes a lot of skill in being able to estimate angles and depth. If you go too deep you'll break into your exhaust port. If you go in at the wrong angle, your exhaust won't go on. A slight misalignment at the head, becomes a large misalignment at the end of the new stud. Good luck. (IMG:style_emoticons/default/sad.gif) Thanks. Tried the weld nut on stud thing, just twisted the stud off again. I was just thinking about it, think i will make a drill guide that i can bolt to the opposite stud with the proper size hole and angle to help guide the drill. If that don't work guess its on to plan d,e, or f-it. |
Wilhelm |
Feb 17 2010, 10:53 PM
Member Group: Members Posts: 408 Joined: 7-September 07 From: Hooterville, OR Member No.: 8,088 Region Association: None |
Pull the head,take it to a machine shop. You'll be money a head compared to ruining your head.
underthetire |
Feb 17 2010, 10:56 PM
PeeGreen 914 |
Feb 17 2010, 11:00 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
You were in a bad band while being a machinest? (IMG:style_emoticons/default/blink.gif)
Couldn't resist (IMG:style_emoticons/default/lol-2.gif) |
underthetire |
Feb 17 2010, 11:29 PM
Hey, old journey rocks. It's when they got that homo steve perry to sing lead is when they turned.
Lo-Fi Version | Time is now: 12th June 2024 - 07:53 AM |
