Fuse label template |
patssle |
Feb 19 2010, 07:17 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Was curious if anybody has made a template to label the newer style fuse boxes that are available from Pelican (as shown below)? Mine are inaccurate for amps/items fused, and I'd like to correct it. I can make my own, but was just curious if anybody already has - save some time.
Thanks. Attached image(s) |
SirAndy |
Feb 19 2010, 09:05 PM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
There's a difference in the layout between early and late.
(IMG:style_emoticons/default/idea.gif) Andy |
JWest |
Feb 20 2010, 09:54 AM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
Was curious if anybody has made a template to label the newer style fuse boxes that are available from Pelican (as shown below)? Mine are inaccurate for amps/items fused, and I'd like to correct it. I can make my own, but was just curious if anybody already has - save some time. Thanks. What do you have a problem with? I believe that I have done my best to make them, not only accurate, but corrected (unless your car has been changed). The original "symbols" are a joke, and the owners manuals were flat out wrong for some of the fuse listings. I carefully traced all the circuits and labeled correctly for each year. Some items are confusing, as a relay for a certain item may be switched from one fuse but powered from another. I also modifed the fuse rating because the 25 amp rating on the early cars were too high. The components fed from those fuses were identical to those used in later years, and the higher amp position were actually loaded up with more items on the newer cars, yet the fuse rating went down from 25 to 16 amps. The factory obviously decided that they had too much headroom for those feeds. |
Lo-Fi Version | Time is now: 11th June 2024 - 06:47 AM |
