MPS mounting hardware, what all came from factory |
scrz914 |
Feb 21 2010, 02:27 PM
Member Group: Members Posts: 398 Joined: 21-April 04 From: Santa Cruz, CA Member No.: 1,960 Region Association: Central California |
Was wondering if any one has a photo or listing of all the parts used in mounting the MPS. Mine has a couple of rubber isolater type washers that the bolts go through, but I've heard that the bolts should also have a brass sleeve?
It seems like care was taken to lessen vibration to the MPS, but then why is the bottom of the bracket secured with sheet metal screws? Or is that something the PO used? Just not sure how these came from the factory or what they were trying to accomplish. Thanks. |
Bleyseng |
Feb 22 2010, 09:41 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Three rubber bushings with brass inserts were used to mount the MPS. The top mount had a bolt that also held the Decel valve to the body. Yes, the two lower mounts used big screws to mount the MPS.
scrz914 |
Feb 23 2010, 10:11 AM
QUOTE Three rubber bushings with brass inserts were used to mount the MPS. The top mount had a bolt that also held the Decel valve to the body. Yes, the two lower mounts used big screws to mount the MPS. Okay, that's what I was guessing. Just need to get some of those rubber washers and with the brass sleeves. Maybe AA? |
Pat Garvey |
Feb 23 2010, 07:52 PM
Do I or don't I...........? Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States |
Three rubber bushings with brass inserts were used to mount the MPS. The top mount had a bolt that also held the Decel valve to the body. Yes, the two lower mounts used big screws to mount the MPS. On the money as usual! But the lower mounts seem a little inconsistent don't they? Pat |
Bleyseng |
Feb 23 2010, 10:55 PM
inconsistent? no, cheap but they didn't have to weld 2 nuts inside of the mps bulkhead so they saved money.
Lo-Fi Version | Time is now: 9th June 2024 - 04:55 PM |
