WTB Warm air sheetmetal and shift rod |
914ltd |
Feb 24 2010, 08:26 AM
Member Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
I need a couple sets of the 73-74 warm air guides. The right, triangular piece 022-119-355 also fits earlier but I am mainly wanting the left, 022-119-356B which has the hump going over the top of the shift rod. The photos are the ones I want. Earlier went under the rod and will not lay flat on a surface.
Also need late rear shift rods 914-424-063-00 in good usable condition, not bent, welded, excessively worn or rusted and the taper pin hole not drilled out. Please PM me with price with shipping. Thanks! Brad Mayeur 309-694-1797 Attached image(s) |
URY914 |
Feb 24 2010, 09:03 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,038 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
PM sent
markb |
Feb 24 2010, 11:57 AM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
If you don't find them, we have some here.
Oldgit |
Aug 12 2010, 03:23 AM
I'm new here ... Group: Members Posts: 0 Joined: 12-August 10 From: United Kingdom / England Member No.: 12,039 Region Association: England |
I also need just one of the LEFT warm air guides (tinware) 022-119-356B
[which has the hump going OVER the top of the shift rod. The photos above show the one I want. Earlier went under the rod and will not lay flat on a surface.] Will take a good used part, or a sensibly priced new one, but need it posting to UK. I did bid on one on eBay (in US), but lost out to a last-minute bid. The seller had said: - "That piece of tin will fit in a medium flat rate box. I think it's a little less than $15.00 US for shipping via US Postal Service - First Class International Postage." That is if he got it right. I had a look on the GPR Parts website - they show shift-rods, but I couldn't find any tinware. If you can help please PM me. |
raw1298 |
Aug 12 2010, 09:31 PM
Senior Member Group: Members Posts: 616 Joined: 9-March 09 From: Rocklin,Ca. Member No.: 10,148 Region Association: Northern California |
I just got the left side off of ebay from AA. 24.00Should be recieving it this week. Says there are 8 left.
914ltd |
Aug 13 2010, 04:04 PM
I've gathered enough of these parts for now. Thank you all! Brad Mayeur
Lo-Fi Version | Time is now: 8th June 2024 - 01:39 PM |
