Torque spec for oil cooler nut |
type47 |
Mar 19 2010, 04:03 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
small nut that clamps the oil cooler to the case. Workshop manual 24.1-2/2 identifies nut as M 6 qty: 2. Workshop manual 0.3-1/2 which is a page of tightening torques does not list one for the oil cooler nuts. Could you tell me the torque spec?
agentblr |
Mar 19 2010, 04:14 PM
Member Group: Members Posts: 303 Joined: 23-January 04 From: Lee's Summit MO Member No.: 1,595 |
Pretty sure it is 7ftlbs.
Shade Tree |
Mar 19 2010, 04:15 PM
Member Group: Members Posts: 260 Joined: 18-December 08 From: Springfield, Oregon Member No.: 9,860 Region Association: Pacific Northwest |
I thought it was eleven (IMG:style_emoticons/default/confused24.gif)
McMark |
Mar 19 2010, 04:16 PM
Good-n-Tite! These are small fasteners, so they won't take a lot. 7lbs is fine. But just 'eyeballing' it is fine too. It's more about keeping the fasteners from loosening than actually clamping the cooler.
11 is probably too high. M8 fasteners only go to 14 mostly. |
ME733 |
Mar 19 2010, 04:48 PM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
............AND ....I squrt Blue Silicone Glue in your general direction, ....while trying to get some on the outside of the seals and crummy POS paper gasket......before torquing with an inch # torque wrench :to ...10 ft lbs.
McMark |
Mar 19 2010, 09:45 PM
Paper gasket? (IMG:style_emoticons/default/blink.gif) Blue Silicone? (IMG:style_emoticons/default/icon8.gif)
ConeDodger |
Mar 19 2010, 10:05 PM
Apex killer! Group: Members Posts: 23,612 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Paper gasket? (IMG:style_emoticons/default/blink.gif) Blue Silicone? (IMG:style_emoticons/default/icon8.gif) It is always good to get some of that in the oil passages too (IMG:style_emoticons/default/blink.gif) |
ME733 |
Mar 20 2010, 07:31 AM
Paper gasket? (IMG:style_emoticons/default/blink.gif) Blue Silicone? (IMG:style_emoticons/default/icon8.gif) It is always good to get some of that in the oil passages too (IMG:style_emoticons/default/blink.gif) .................WELL to bad you cant read.Try reading my post again., the blue rtv silicone engine sealer goes on the OUTSIDE of the oil cooler seals....and the paper gasket goes between the engine case and the oil filter mount....that should have some sealer on both sides....But in YOUR particular case, with apparently and OBVIOUSLY your lack of experience, finese, and common sense YOU should NOT use any sealer for the reason you stated....YOU... will get it into the oil passages when the mount , or cooler is torqued down...............murray |
Lo-Fi Version | Time is now: 8th June 2024 - 01:44 AM |
