Headlight problem |
Headlight problem |
luvatenor |
Mar 21 2010, 09:08 AM
Newbie Group: Members Posts: 47 Joined: 20-December 09 From: NY Member No.: 11,154 Region Association: None |
I pull the headlight switch all the way out, but the headlights do not raise.I manually rise them to the full upright position, and when I push the switch in all the way, the headlights retract perfectly together. Anyone have a similar problem or a solution?-I have cleaned the grounds and switched the relays- Thanks-Rolf
Tom_T |
Mar 21 2010, 10:32 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Wires reversed somewhere? (IMG:style_emoticons/default/confused24.gif)
... or did you change the mechanism working on them & get the arms/drive on bass-ackwards? (IMG:style_emoticons/default/confused24.gif) |
luvatenor |
Mar 22 2010, 07:44 AM
The linkage is correct- has to be electrical- new twist when I pull on the high beam lever, they go up and stay and the high beams blink- someone did something to this car- wasn't me
VaccaRabite |
Mar 22 2010, 08:09 AM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Sounds like they may be tied to the turn signals somehow.
Start tracing wires and matching them against the electrical diagrams. Zach |
Lo-Fi Version | Time is now: 1st June 2024 - 10:45 AM |
