luvatenor
Mar 21 2010, 09:08 AM
I pull the headlight switch all the way out, but the headlights do not raise.I manually rise them to the full upright position, and when I push the switch in all the way, the headlights retract perfectly together. Anyone have a similar problem or a solution?-I have cleaned the grounds and switched the relays- Thanks-Rolf
Tom_T
Mar 21 2010, 10:32 PM
Wires reversed somewhere?
... or did you change the mechanism working on them & get the arms/drive on bass-ackwards?
luvatenor
Mar 22 2010, 07:44 AM
The linkage is correct- has to be electrical- new twist when I pull on the high beam lever, they go up and stay and the high beams blink- someone did something to this car- wasn't me
VaccaRabite
Mar 22 2010, 08:09 AM
Sounds like they may be tied to the turn signals somehow.
Start tracing wires and matching them against the electrical diagrams.
Zach
