What type of engine is in this youtube 914 |
tornik550 |
Mar 25 2010, 06:29 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
Does anybody know what type of engine is in this 914. It looks extremely fast.
I am setting up my 914 for autoX. This looks like a good car to model after. http://www.youtube.com/watch?v=Vd77YaGoVQQ |
Mike Bellis |
Mar 25 2010, 06:41 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
It sounds like a rotary. I had one in my 63 VW bus. It was stupid fast. A stock 13B is around 165hp without a turbo. With a turbo, porting, bigger injectors... 500hp is possible. the 13B is 1.3 liters and almost half the size of a T4 engine.
brilliantrot |
Mar 25 2010, 07:15 PM
Member Group: Members Posts: 125 Joined: 27-April 07 From: Costa Mesa Ca. Member No.: 7,699 |
Sounds and looks like just a hot carbed T4 with a Supertrap.
URY914 |
Mar 25 2010, 07:29 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,944 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I was thinking a big -4 too.
Rand |
Mar 25 2010, 08:44 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Definitely not a rotary. A 4, running a little rough at times.
tomeric914 |
Mar 25 2010, 08:45 PM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
Sounds like my 2270, except that one appears to have a miss. Sounds like it's too rich, has a clogged jet or a float setting problem.
orange914 |
Mar 25 2010, 10:44 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
Jake Raby |
Mar 25 2010, 11:09 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Sounds familiar...
I am pretty sure thats the same car as this video. I have a customer who runs my engine in dual AX/ DE events in that region and to me, that sounds like one of my engines.. His car is also yellow AFAIK. He is ONE HELL of a driver and if you look close the tach can be seen mounted in the same place on the dash as the car in the video.. Note that the tach STARTS at 5,000 RPM.. The engine is good for 8,700 RPM. Powerband is between 3000-7700 RPM. http://www.youtube.com/watch?v=y13C3v2L788 Here is his first outing on the big track from a while back, same engine.. Dual purpose BEAST! http://www.youtube.com/watch?v=1uFRrbjy_pM There is a chance that it isn't the same car, but I doubt it... He never sent me pics, but from the way this guy drives and the region and engine sound it damn near has to be. That stumble you hear is the fuel spilling over the floats in the carbs as the G force impacts it, especially at lower RPM.. It makes the engine go full rich for a second, then it screams to life. That could be tuned out with float height adjustments, or by going to a pair of Dellortos from the Webers that it currently has... Just little old 44s breed that beast to 218HP. IF its the same car/engine that I believe it is. This post has been edited by Jake Raby: Mar 25 2010, 11:17 PM |
Porcharu |
Mar 26 2010, 12:52 AM
Senior Member Group: Members Posts: 1,314 Joined: 27-January 05 From: Campbell, CA Member No.: 3,518 Region Association: Northern California |
It sounds like a rotary. I had one in my 63 VW bus. It was stupid fast. A stock 13B is around 165hp without a turbo. With a turbo, porting, bigger injectors... 500hp is possible. the 13B is 1.3 liters and almost half the size of a T4 engine. Sounds like a rotary - your kidding I hope. Hot rotary's sound like an angry swarm of hornets. That car sounds like a flat four with a header and not much muffler. I used to run with a guy that had a Triumph with street ported 12A and that thing sounded evil - fast as hell too. |
sean_v8_914 |
Mar 26 2010, 09:02 AM
Chingon 601 Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
a type 4 with clogged idle jets
Lo-Fi Version | Time is now: 1st June 2024 - 08:25 AM |
