Installing New Brakes (thanks Eric!), Are these speed bleeders? |
rjames |
Apr 4 2010, 10:03 AM
I'm made of metal Group: Members Posts: 3,949 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I am finally getting around to installing the calipers I ordered from PMB. Others have said it before, but I will say it again: these things are beautiful! The brakes will probably be the nicest parts on my car! (IMG:style_emoticons/default/biggrin.gif)
These bleeders were on my old calipers and look different than the ones supplied with the restored calipers. Are these speed bleeders? If so I may decide to use them instead. Of course I'll need to clean them up first. |
realred914 |
Apr 4 2010, 11:23 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
I am finally getting around to installing the calipers I ordered from PMB. Others have said it before, but I will say it again: these things are beautiful! The brakes will probably be the nicest parts on my car! (IMG:style_emoticons/default/biggrin.gif) These bleeders were on my old calipers and look different than the ones supplied with the restored calipers. Are these speed bleeders? If so I may decide to use them instead. Of course I'll need to clean them up first. the speed bleeders have a spring loaded check valve in the end that goes into the caliper. I dont see that on this one. |
McMark |
Apr 4 2010, 11:35 AM
If you can't blow thought the nipple side, it's a speedbleeder.
Attached image(s) |
rjames |
Apr 4 2010, 11:56 AM
Ok, thanks for the info. These are not speed bleeders then.
Were there two different bleeder styles- maybe earlier and later? My car is a '75. The ones I got from Eric are shorter. And unlike the ones shown here, the others don't allow for a socket to fit over them because of their width at 'nipple' end. |
realred914 |
Apr 4 2010, 12:02 PM
i have seen fat and skinny ones on the 914 also they may be repalced with generaic ones. ones off a VW bugh also fit. for best life, always use a nice 6 point wrench or socket to prevent stripping the flats and I always lube the threads with brake grease (do NOT use non-brake grease else the rubber parts inside may fail, even trace amounts of regular grease will ruin the brakes)
besure to have the rubber caps put back on the bleeders also, that keeps water out which if allowed in with quickly corrode the valve. |
Lo-Fi Version | Time is now: 4th June 2024 - 09:07 PM |
