Time to start on my big Type IV motor, Bigger is not always better |
veltror |
Apr 5 2010, 06:04 PM
Senior Member Group: Members Posts: 928 Joined: 27-April 08 From: Potters Bar Herts UK Member No.: 8,978 Region Association: None |
Gentlemen,
Some years ago, April 98 to be precise, I bought a 2.6 L stroker kit from European racing, with a J Cam 307 Dur. The plan then was to put it into my 1303 Beetle, but things changed and i never did anything, but I did source some parts. (IMG:style_emoticons/default/smile.gif) Those who have been following my British Rustoration thread can see that I still have a lot more work to do on the body but I think it might be time to start putting th lump together. Now I thought I had a 78 Stroke crank and 103 pistons so I should get a 2600, but on inspecting the pistons they say 104. This makes it 2650, I think it may be too big besides petrol is not free here like it is in the US. (IMG:style_emoticons/default/poke.gif) The good news is my new Type 4 case looks ok, although I do not like the oil breather bit so some machining will be needed here. The case has a part number of 071101101 so it look like a late air-cooled case. (IMG:style_emoticons/default/idea.gif) Plan is to go with a microsquirt system since carbs would need to be 45's which is more cash, might as well go modern-tech. I will update this thread as things progress, please feel free to add comments or criticism . Attached image(s) |
URY914 |
Apr 5 2010, 06:09 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,944 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Very nice, keep posting.
Mark Henry |
Apr 5 2010, 06:45 PM
Run the pistons, 1mm won't save you gas.
The case is a late bus or vanagon case. Spec it out good as they tend to be beat from pushin the heavy bus around. Sump P/U is shorter and will need a slight mod if running a 914 windage tray. That will run with 44 webers (45dells) just fine, the MS will cost you more if you use ITB's. Although I like PEFI, carbs will always be cheaper. |
veltror |
Apr 5 2010, 06:48 PM
i forgot to say, the case is brand new, and yes I will use ITB's and of course your trigger wheel, will have to see what the MS system costs out to...
Thanks for the comments. R |
Mark Henry |
Apr 5 2010, 06:57 PM
Cool about the new case, the only issue will be a dipstick, but no biggie.
Wrong Mark on the trigger wheel;) |
veltror |
Apr 6 2010, 06:44 PM
Amazing what you find on ebay here a new cylinder tin.
Attached image(s) |
Lo-Fi Version | Time is now: 1st June 2024 - 07:53 AM |
