Does someone here make the WIndshield seal with clip inside?, replacing dash top material and need this seal |
budman5201 |
Apr 27 2010, 09:37 PM
Senior Member Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 |
does someone here make the windshield seal between the window and the dash with the clip in the middle?
I need the material for top of dash also the foam and this seal... thanks guys |
bandjoey |
Apr 27 2010, 10:23 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Mikey
914rubber.com vendor section or multiple posts herein the garage. He's the rubber king. (IMG:style_emoticons/default/smilie_pokal.gif) |
jaxdream |
Apr 27 2010, 10:25 PM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
Check the vendor's section of the forums , Mikey914 ( Mark ) sells all kinds of quality rubber seal replacments, he has this one also , send him an email to check if he has one in stock . Also look around your teener , there may be other seals you could use , he probably has those too . The dash stuff get from morph , he's in the vendors section also. God luck ....
Jack / jaxdream |
budman5201 |
Apr 27 2010, 10:28 PM
Check the vendor's section of the forums , Mikey914 ( Mark ) sells all kinds of quality rubber seal replacments, he has this one also , send him an email to check if he has one in stock . Also look around your teener , there may be other seals you could use , he probably has those too . The dash stuff get from morph , he's in the vendors section also. God luck .... Jack / jaxdream thanks ! |
dr914@autoatlanta.com |
Apr 28 2010, 08:52 AM
914 Guru Group: Members Posts: 7,885 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Mikey914 |
Apr 29 2010, 10:23 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
That's the way I made mine, without the steel clip. I was planning to put the aliminum in, but after plating aound with it found it would be a big pain in the butt to install with the clip. That way it can install without removing the windshield. There's a thread I did on this about a year ago.
Lo-Fi Version | Time is now: 31st May 2024 - 07:20 PM |
