'75 1.8 Rough Cold Start and Idle |
andrewvolsen |
Apr 29 2010, 01:22 PM
Newbie Group: Members Posts: 44 Joined: 6-December 09 From: Santa Barbara Member No.: 11,099 Region Association: Central California |
My '75 1.8 L-jet FI car starts and runs very rough when cold. If I wait less than 5 minutes idling it for warm up before driving, it stumbles, sputters and dies. When cold, if I give it a little gas (2000-2500 rpm or so in neutral) it won't settle back down to idle; it drops way below idle speed and often stalls. Is this normal? My odometer also stopped working the other day. The speedometer still works, but the odometer does not. What are there common causes for this?
Andrew |
Cupomeat |
Apr 29 2010, 01:24 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
I have a similar issue with my 914 1.8 L-jet, so I am (IMG:style_emoticons/default/popcorn[1].gif)
I have been trying to fix this for 2 years now and am about to give up and completely tear off the FI, and go through every piece with a fine tooth comb (magnifying glass) and reassemble. I think it is a vacuum leak, but can't find it yet. |
dr914@autoatlanta.com |
Apr 29 2010, 02:38 PM
914 Guru Group: Members Posts: 7,885 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
My '75 1.8 L-jet FI car starts and runs very rough when cold. If I wait less than 5 minutes idling it for warm up before driving, it stumbles, sputters and dies. When cold, if I give it a little gas (2000-2500 rpm or so in neutral) it won't settle back down to idle; it drops way below idle speed and often stalls. Is this normal? My odometer also stopped working the other day. The speedometer still works, but the odometer does not. What are there common causes for this? Andrew Hi Andrew. ODO is the gear best to let the vdo rebuilder handle it. Cold running can be a number of things starting with valve adjust compression dwell and timing Then vacuum leaks fuel pressure and then head temperature sensor aux air valve. By the time you check and fix these your problem will be solved. |
Lo-Fi Version | Time is now: 31st May 2024 - 11:27 PM |
