Lost brakes on the way home, speedbleeder failure!, Talk about random |
ghuff |
May 2 2010, 06:03 PM
This is certainly not what I expected down here. Group: Members Posts: 849 Joined: 21-May 09 From: Bodymore Murderland Member No.: 10,389 Region Association: MidAtlantic Region |
Had a speedbleeder die today running around during my lunch break at work.
(IMG:style_emoticons/default/beerchug.gif) Drove home with the ebrake. I am now kind of sketched about them after this. |
ghuff |
May 2 2010, 06:04 PM
turboman808 |
May 2 2010, 07:24 PM
Advanced Member Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
Used them probably 10 years ago and had them stop working properly. I never wanted to really say they sucked or are dangerous because there is always human error(something I did).
But to play it safe I stopped using them. Never had a problem with regular bleeders. |
detoxcowboy |
May 2 2010, 08:24 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Thanks for sharing that, I was using them recently too and felt they just were cheaply functional..
iamchappy |
May 2 2010, 08:55 PM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
Did they leak past the threads or actual nipple. This is very important as i have them
and would hate to loose my brakes when i am ripping. |
ghuff |
May 3 2010, 06:52 AM
Did they leak past the threads or actual nipple. This is very important as i have them and would hate to loose my brakes when i am ripping. The nipple. i have a nice video the wife and I took of the nipple leaking fluid on every brake pedal depress. I am going to put it on youtube and link it here..... i put another speedbleeder back in there for now but I think I am going to swap them all out and go back to normal bleeders in the not too distant future..... To give you an idea, i was doing 120mph yesterday morning, WOT full boost and this happened a few hours later...... Definitely not good. I mean the pedal decayed before it started going to teh floor, but it was not good enough. Even though my 2001 GTI has a dual circuit master it sure did not feel like it, the pedal physically against the floor slowed me about 1mph per second at most |
KELTY360 |
May 3 2010, 08:03 AM
914 Neferati Group: Members Posts: 5,036 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
charliew |
May 3 2010, 08:21 AM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
I have not used speed bleeders in the 2001 gti caliper but: I have looked at speedbleeders and it looked like when the tip is seated with the speedbleeder it is just like the stock bleeder. The only way the speedbleeder should let fluid pass is when it is backed off and not seated. Either the seat is damaged or the taper is the wrong size if the speedbleeder is truly tight against the seat. Are you sure you used the right speedbleeder for the caliper you have? It seems like a close examination of the original bleeder and the speedbleeder would show any differences.
EdwardBlume |
May 3 2010, 08:24 AM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
Very scary... brake loss if not gradual is bad news....
ghuff |
May 3 2010, 09:00 AM
I have not used speed bleeders in the 2001 gti caliper but: I have looked at speedbleeders and it looked like when the tip is seated with the speedbleeder it is just like the stock bleeder. The only way the speedbleeder should let fluid pass is when it is backed off and not seated. Either the seat is damaged or the taper is the wrong size if the speedbleeder is truly tight against the seat. Are you sure you used the right speedbleeder for the caliper you have? It seems like a close examination of the original bleeder and the speedbleeder would show any differences. I agree. It is a simple thing, full seat area contact = no leak. It was tightened fully, and I am about to go out to the garage any break the dial caliper out on the old bleeders as well as the removed speedbleeder. |
ghuff |
May 3 2010, 09:01 AM
To give you an idea, i was doing 120mph yesterday morning, WOT full boost and this happened a few hours later...... Was this on the street? Yeah, what? I was late getting my daughter to the baby sitter and had not had my coffee yet. |
charliew |
May 3 2010, 09:15 AM
I hope the aluminum caliper isn't stripped. I had bought some speedbleeders but went out to the shop to look at them and of course they are "put up" I guess.
ghuff |
May 3 2010, 10:39 AM
The pattern on the contact seat of the bleeder is there for all but 60 degreees of the seating surface.
There was a good 3-4mm between the hex and caliper body..... Makes me wonder if my calipers are not within spec and causing the leak. I recall the old bleeder screws were this long. I am going to pull the other rear to inspect it. I need to find the old bleeder screws to compare, going back 1 month in my garage is an eternity. |
KELTY360 |
May 3 2010, 11:07 AM
To give you an idea, i was doing 120mph yesterday morning, WOT full boost and this happened a few hours later...... Was this on the street? Yeah, what? I was late getting my daughter to the baby sitter and had not had my coffee yet. I was just asking. Did I say something wrong? |
ghuff |
May 3 2010, 11:46 AM
I hope the aluminum caliper isn't stripped. I am working from home today and I am miffed.... I recall comparing threaded length on the removed factory bleeder versus this and it being the same. The bleeder took force to remove, it was fully seated and you can see space between the hex portion of the screw and the caliper body..... http://img256.imageshack.us/img256/7422/p5021280.mp4 |
ghuff |
May 6 2010, 06:27 AM
To give you an idea, i was doing 120mph yesterday morning, WOT full boost and this happened a few hours later...... Was this on the street? Yeah, what? I was late getting my daughter to the baby sitter and had not had my coffee yet. I was just asking. Did I say something wrong? Nobody took the bait from my attempted troll! Damn. I crack it open sunday mornings & late at night going to/coming from work on a stretch of highway here with no on/off ramps or places for people/things to get in the way should something happen. I drive it very sedately in traffic, residential areas, and around town in general. |
Lo-Fi Version | Time is now: 8th June 2024 - 04:24 PM |
