3 Pages V  1 2 3 >
> 4 lug - anyone install studs and nuts, bolts suck : )
jimkelly
post May 8 2010, 06:10 AM
Delaware USA
i'd prefer studs so i can just thrown the wheel/tire onto the rotor without the whole orientation dance of hands a feet : )
914Sixer
post May 8 2010, 06:21 AM
I have been considering doing it and using 911 allow nuts. The only draw back I can see is you have to know what wheels you are going to use. Stock alloy wheels will require longer studs than the factory steel wheels. To use a steel wheel you would need the steel wheel nuts like the 914-6 or 911 uses. Not sure if the black plastic lug bolt covers will cover the nut though. I will check on that part this morning.
jimkelly
post May 8 2010, 06:43 AM
Delaware USA
for 4 lug fuchs, i would need something like this.
http://www.928motorsports.com/parts/lugnuts.php
benalishhero
post May 8 2010, 08:04 AM
I made my own studs on my car with A/M nuts. They work great and were a fraction of the cost of stock bolts.
DanT
post May 8 2010, 09:18 AM
Going back to the Dark Side!
Check here....studs and nuts
Several styles to choose from..
McMark
post May 8 2010, 09:21 AM
914 Freak!
Uh-oh, here comes the thread in stud debate. (IMG:style_emoticons/default/hide.gif)
DanT
post May 8 2010, 09:31 AM
QUOTE(McMark @ May 8 2010, 08:21 AM) *
no debate (IMG:style_emoticons/default/biggrin.gif)
DanT
post May 8 2010, 09:44 AM
they work quite well when you choose good quality and install them correctly
these pics show BBS racing screw in studs...tough to really see since 1/2" and 3/4" spacers were still inplace over the studs...these were 80mm, so I could run large spacers and 3 different sets of wheels/tires.
Chris Pincetich
B-)
I've used racing studs for 2+ years, they have the most thread engagement. The ones with the hex bolt inside the end do not screw as far in. When I was swapping wheels for every AX race, they made a huge difference (IMG:style_emoticons/default/beerchug.gif)
root
post May 8 2010, 10:00 AM
Two Wheeled Type4 Completed!
Seems like alot of effort just to avoid the 'studly' wheel installation required
with standard lug bolts. But if you do convert to 'studs' the question will be...
How many 'studs' do you really have 16 or 17 (if you include the driver)? (IMG:style_emoticons/default/stirthepot.gif)
realred914
post May 8 2010, 10:28 AM
Group: Retired Members
how oft do you change wheels? is it realy wroth th eeffort to save labour????
guess I am too used to wheel bolts rather than studs. my whole life since a kid we had cars with bolts
DanT
post May 8 2010, 11:04 AM
If you change wheels with a different seat, you can just get a new set of lug nuts instead of the cost of complete new set of lug bolts.
I will have a set of Rivs for street with 60* cone seat and Fuchs with the ball seat for the competition tires...
just need 16 nuts instead of a complete set of lug bolts (IMG:style_emoticons/default/biggrin.gif)
If you are AXing or DE/TT you change or at least remove your wheels often and the studs make it much more efficient, especially at an event.
Bartlett 914
post May 8 2010, 11:50 AM
I use wheel hangers when changing my wheels. Makes a world of difference. I also use 2 of them when doing a valve adjustment. with 2, I can put a bar between them and use the bar to lock a wheel while I rotate the other wheel. I just screw one in hand tight and place it at 12 o'clock. Hang the wheel and install the bolt. Using 2 makes this even easier. I sell them 15 each 25 for 2.
ChrisFoley
post May 8 2010, 12:05 PM
I am Tangerine Racing
If you have hubcentric wheels here's another solution for the rear.
The wheels stay on without lug nuts.
jimkelly
post May 8 2010, 12:44 PM
Delaware USA
Tom_T
post May 8 2010, 01:37 PM
TMI....
QUOTE(jimkelly @ May 8 2010, 05:10 AM) *
But Jim, that's half the charm of owning a 914!
... btw - you forgot use of forehead in your dance! (IMG:style_emoticons/default/biggrin.gif)
Chris Hamilton
post May 8 2010, 04:01 PM
studs:
http://www.hamiltonracing.net/photos/red914/CIMG0111.jpg
http://www.hamiltonracing.net/photos/red914/CIMG0124.jpg
charliew
post May 8 2010, 05:06 PM
Chris are those rings a press fit in the rotor or are they trapped in between the rotor and hub?
JimN73
I was going to use studs. I found that using 50 mm on the front and 65 in the back - because the stud threads into the hub behind the rotor and not into the rotor as the front does. I could use 911 alloy lug nuts and get a finished look. My spare wheel is a steel wheel and is only 1/8 or so I'd need a set of open lug nuts for the spare - I cut down some 911 alloys for this.
Then I got a set of EMPI 8 spoke for autocross and the plan went out the window. The EMPIs are only half as thick as the Fuchs so I would need set of open lug nuts like the ones JimKelly shows in an earlier post for those.
Go to be too much work and too many pieces. My workaround is to screw two studs a few turns into the hub, mount the wheel and put two bolts in, remove the studs and add the second two bolts. Doesn't take long and I don't have 32 lug nuts laying around at the autocross.
scotty b
post May 8 2010, 05:10 PM
rust free you say ?
Chuck Norris just tells his wheels to stay on the car...and they do.............no nuts or studs needed
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 15th June 2026 - 05:31 AM
