> what you got for guts, alternative internals for our motors
rsrguy3
post May 12 2010, 09:40 PM
Is there a list of alternative internals(non-vw) for our rebuilds that would make our re-builds cheaper and stronger, Example... Chevy rods. Consider this a tips and tricks thread, as well. Also, I don't have good experiences w/the forum search, so please place as many links as you can dig up, here. (IMG:style_emoticons/default/biggrin.gif)
Mike Bellis
post May 12 2010, 10:30 PM
Resident Electrician
I got 2 squirrles, a penguin and a raoch stuffed in there. You should hear that motor scream...
DanT
post May 12 2010, 10:37 PM
Going back to the Dark Side!
KB 96mm Hyperutectic Aluminum pistons, stock Mahle cylinders machined to 96mms and Raby 9550 cam...the rest was stock and worked well together (IMG:style_emoticons/default/biggrin.gif)
VaccaRabite
post May 13 2010, 08:38 AM
En Garde!
I used the same pistons and cylinders for my 2056.
I am also using ceramic lifters instead of steel (NLA, but great if you can find them).
My engine is carbed, so I have more choice in dizzys. I am using a Mallory Unilite, and a Bosch Blue coil.
Zach
blitZ
post May 13 2010, 09:34 AM
Beer please...
QUOTE(kg6dxn @ May 12 2010, 11:30 PM) *
You can't penguin a 914...
I have the same setup as DanT, works like a charm.
warrenoliver
post May 13 2010, 09:46 AM
QUOTE(DanT @ May 12 2010, 11:37 PM) *
Dan,
Did you dyno your engine after these improvements? I am wondering what kind of HP increase I can expect if I go this route with my 2.0.
I am not ready to go all in on a Raby 2270 but I sure would like to (IMG:style_emoticons/default/drooley.gif) - I just can't afford it right now. What kind of HP increase over stock 73, 2.0, with FI, could I expect with new pistons/cylinders and a Raby cam?
Anyone have any idea on cost for this type of "improvement"?
Warrenoliver
McMark
post May 13 2010, 09:52 AM
914 Freak!
2056 motor are a blast compared to any stock motor.
Cevan
post May 13 2010, 09:53 AM
My 2056 consists of Kieth Black pistons, AA cylinders, Hastings rings, Raby 9050 cam and valvetrain, 1.7 rockers with swivel adjusters, 2.0 heads, Manton pushrods, stock crank, H-beam connecting rods.
EdwardBlume
post May 13 2010, 10:15 AM
Those are some nice engines!
With regards to HP, 95 to 115, or 95 to 125, especially with some suspension improvements and weight reduction makes a big difference...
rsrguy3
post May 13 2010, 10:33 AM
So, which Chevy rods are used? And what about the Buick crank? Loving the pics guys keep it up.
TROJANMAN
post May 13 2010, 10:39 AM
Looks nice in pictures.........
The most popular conversions are :
Porsche 6's, Chevy 8's, Suby 4's
Here's my 2.7
(IMG:http://www.914world.com/bbs2/uploads_offsite/209.85.48.8-1753-1273768804.1.jpg)
More Pics of Conversion
xperu
post May 13 2010, 10:50 AM
TEXAS
QUOTE(Cevan @ May 13 2010, 10:53 AM) *
Hey george, what type and model are you using for that nice power plant? Mike
70_914
post May 13 2010, 11:08 AM
A lot of performance VW's use SBC valve springs after a lot of machine shop time, but all the other parts are specific for the engine. There are a lot of counterweighted cranks machined for SBC rod journals, but not SBC rods.
tat2dphreak
post May 13 2010, 12:59 PM
stoya, stoya, stoya
9.5:1 CR + 10# flywheel=hang on (IMG:style_emoticons/default/smile.gif)
I am running AA piston cylinders, webcam 163, dual spring valves, stock 2.0 crank and rods, 911 adjusters.
you would not believe what shaving 7 lbs off the flywheel does...
rsrguy3
post May 13 2010, 09:35 PM
Just for clarity..... I'm talking about the type 4 motor and it's internals.
rsrguy3
post May 13 2010, 09:42 PM
QUOTE(70_914 @ May 13 2010, 09:08 AM) *
So, your saying no Chev con's, just journals? The reasoning behind this? How about the Buick crank? Is there a con rod made for a different motor, like a v8 motor that dimensionally similar/stroke (you know get 8 for 4)? (IMG:style_emoticons/default/dry.gif)
azbill
post May 13 2010, 11:39 PM
I am running a 2056 with Keith Black pistons, Len Hoffman heads, Raby cam, stock crank and rods, Jennvey 45mm throttle bodies, Emerald M3D FI management, SS heat exchangers and Triad exhaust. The set-up dynoed 150hp at the wheels. Its great.
Bill
- Lo-Fi Version Time is now: 31st July 2025 - 07:25 PM
