MSD billit distrib problem, no wonder it rus like sh**t |
fitzm1 |
May 24 2010, 11:29 AM
Member Group: Members Posts: 74 Joined: 21-April 08 From: Ballston lake,ny Member No.: 8,947 Region Association: None |
john rogers |
May 24 2010, 12:18 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
It appears that the moisture in the crankcase is being vented out through the distributor past the shaft and collects in the top due to the cap fitting tightly. I would recommend checking the PCV valve to make sure it is clean and free and going to the intake plenum and if you have carbs then make sure that the case and heads are vented to a large vent box and that the foam in it is clean and allows the crankcase to breath.
fitzm1 |
May 24 2010, 04:36 PM
It appears that the moisture in the crankcase is being vented out through the distributor past the shaft and collects in the top due to the cap fitting tightly. I would recommend checking the PCV valve to make sure it is clean and free and going to the intake plenum and if you have carbs then make sure that the case and heads are vented to a large vent box and that the foam in it is clean and allows the crankcase to breath. I have carbs with this vent box. Vents from the crank case and cylinder heads. Has no filter just a small amount of oil in bottom of box. |
SirAndy |
May 24 2010, 04:58 PM
Resident German Group: Admin Posts: 41,677 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I have carbs with this vent box. Vents from the crank case and cylinder heads. Has no filter just a small amount of oil in bottom of box. The box is supposed to be mounted higher (so the oil can drain back) and open to the environment. The top should not seal, it's supposed to have a lip on the underside that prevents it from sealing the box when screwed down. The box also should have a sponge inside to trap the oil vapors so they can condense back into oil and accumulate at the bottom, then drain back. Make sure that box has not been sealed ... (IMG:style_emoticons/default/shades.gif) Andy |
SirAndy |
May 24 2010, 05:01 PM
Here's a pic of my breather box when i still had the 2056 ...
(IMG:http://www.914world.com/bbs2/uploads/post-2-1139248174.jpg) (IMG:style_emoticons/default/popcorn[1].gif) Andy |
Dr Evil |
May 24 2010, 07:47 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Fascinating (IMG:style_emoticons/default/popcorn[1].gif)
KaptKaos |
May 24 2010, 08:16 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Here's a pic of my breather box when i still had the 2056 ... (IMG:http://www.914world.com/bbs2/uploads/post-2-1139248174.jpg) (IMG:style_emoticons/default/popcorn[1].gif) Andy Hey, those carbs look familiar! To add, mount the box like Andy's was. |
76-914 |
May 24 2010, 08:28 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Question. What does that oil that you drain back, look like? Is it yellowish? (IMG:style_emoticons/default/idea.gif)
SirAndy |
May 24 2010, 10:44 PM
Question. What does that oil that you drain back, look like? Is it yellowish? (IMG:style_emoticons/default/idea.gif) Only if you have a lot of moisture in it. Otherwise, it should look like any other motor oil ... (IMG:style_emoticons/default/shades.gif) Andy |
McMark |
May 25 2010, 11:25 AM
Mounting the vent box higher is not a requirement. If you don't and if you have a lot of oil vapor collecting in the box, you can find that it will fill up the box. So if it's lower, just keep an eye on it.
Also, if you do mount the box higher you should think about removing the valve from the PCV system. The valve will keep oil from draining back to the crankcase anyway, and if you fill that line with oil, it could keep the valve from opening and then you have NO crankcase ventilation which IS bad. (IMG:style_emoticons/default/cool.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 05:45 PM |
