weber 44, correct jetting |
bernbomb914 |
Apr 4 2004, 09:40 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
bought a new set of weber 44 for my 2270 engine.
What jets do you suggest to start with? street only. I wishKit had his FI pkg ready but I cant wait any longer. Bernie |
Joseph Mills |
Apr 4 2004, 11:30 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
Have you installed the carbs? If so, are you looking to straighten out a problem, or exact more performance? If it's problems, what are the symptoms?
With your displacement, I assume you do not have a stock cam. With my smaller engine (2.0) and mild cam, my 44's work well with 32mm chokes, 50 idle, and 125 mains. I tried both larger idles and mains. At full throttle, "maybe" it ran better, but on the street it certainly didn't. Too damn rich. Ask anyone that was at the MUSR in Hot Springs last year. Belching blue flames out the exhaust. A leaking header at the cylinder didn't help. Theoretically, you may be able to run everything larger. I've got some 55 idles and either 130 or 135 mains you can borrow it you want to experiment. Just cost you some postage. And you could probably use a 34mm choke with your larger displacement. Do you know what size you have now? Unfortunately, this information is pretty much useless because I am no expert in the black-art of carbs, but I bet some of the pro's will jump in and school us. (IMG:style_emoticons/default/laugh.gif) |
Joseph Mills |
Apr 4 2004, 11:41 PM
Forgot to mention. I just now listed some Italian made 48 IDA's for sale on Ebay. A guy from CA called twenty minutes later, wants to put them on his 550 Beck Spyder.
Now those would bring your 2270 puppy to life! (IMG:style_emoticons/default/wacko.gif) Just kidding. You would hate them. Those 44's will be more than ample. |
Lo-Fi Version | Time is now: 8th June 2024 - 06:01 PM |
