> flares, tire widths, offset combos, what are yours?
RJMII
post May 27 2010, 09:23 AM
Jim McIntosh
What tire sizes are you running with your flares?
What wheels sizes?
What offset and spacer combo are you using?
How much space between the tire and the inside of the flare?
How much space between the tire and the inner fender?
What set of flares did you use?
gothspeed
post May 27 2010, 10:21 AM
I will be using AA steel flares with Fuchs standard offset 7x16 fronts and Fuchs 944 turbo offset 8x16 rears . Tires will be 205/50 fronts and 225/45 rears.
I believe I will need about 1" spacers all the way around but will not buy any untill the flares are installed.
I will want about .5" rear tire to flare gap and about 1-1.5" tire to flare gap front.
Dr Evil
post May 27 2010, 10:53 AM
Send me your transmission!
Poor form, Jim (IMG:style_emoticons/default/jerkit.gif) (IMG:style_emoticons/default/poke.gif)
RJMII
post May 27 2010, 11:30 AM
Jim McIntosh
QUOTE(Dr Evil @ May 27 2010, 10:53 AM) *
Blame it on the percodan/endodan. (IMG:style_emoticons/default/headbang.gif)
Stupid leg is swollen up again.
How would you word it, eh? (see, it's the pain meds, I'm speaking Canadian)
post May 27 2010, 11:49 AM
Resident German
QUOTE(RJMII @ May 27 2010, 08:23 AM) *
This should be easy, there are only a couple of hundred possible wheel/offset/tire combos out there ...
(IMG:style_emoticons/default/rolleyes.gif) Andy
RJMII
post May 27 2010, 12:38 PM
Jim McIntosh
QUOTE(SirAndy @ May 27 2010, 11:49 AM) *
I was able to find yours in a search...
If I could get another dozen solid answers, with numbers and less rolling eyes and (IMG:style_emoticons/default/poke.gif)s I could probably set up my algorithm for this little project I'm working on. (IMG:style_emoticons/default/beerchug.gif)
I'm pretty sure my questions were pretty straight forward and easy to answer. (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/shades.gif)
RoninEclipse2G
post May 27 2010, 12:53 PM
Suby Geek
He didn't ask what he SHOULD run, but rather what EVERYONE ELSE was running.
C'mon guys. It's not that hard (IMG:style_emoticons/default/tongue.gif)
jhadler
post May 27 2010, 01:06 PM
Long term tinkerer...
Alright, I'll be the first to actually answer his question...
225/45-15 tires
15x8 custom wheels with 4-7/8" backspace
Stock front fenders - slight rub at full lock.
Hand rolled and pulled rear fenders - snug, but clears with no rubbing.
-Josh2
Dr Evil
post May 27 2010, 01:42 PM
Just giving you a hard time, Jim (IMG:style_emoticons/default/smile.gif)
zig-n-zag
post May 27 2010, 02:15 PM
I want to use 911 turbo hubs for the front in an effort to eliminate
spacers, but don't know if that is a good thing. Scrub radius issue?
Late 911 hub-centric rear hubs might increase the rear track over the early lug-centric ones, 1/4" difference?
Ultimate wheel combo for me would be 944T 8x16 fronts, 911 9x16 rear,
or 8's all around, but might take the easy way out and go with all 7's. I
recall someone said the AA flares can't fit 9's without massaging them,
and for the use of 8's up front as well.
post May 27 2010, 02:36 PM
914-6 GT in waiting
What tire sizes are you running with your flares? 205x55x15 & 225x50x15
What wheels sizes? 7x15 & 8x15
What offset and spacer combo are you using? 5 lug Fuchs, 20mm spacer on front, no spacer on rear
How much space between the tire and the inside of the flare? Don't know yet.
How much space between the tire and the inner fender? Don't know yet.
What set of flares did you use? AA steel flares from the world famous group buy (IMG:style_emoticons/default/biggrin.gif)
PlaysWithCars
post May 27 2010, 09:55 PM
QUOTE(zig-n-zag @ May 27 2010, 01:15 PM) *
I borrowed a set of 8s and 9s from a buddy and ran on my car for one autocross. 245s in back and 225s up front. Worked great and looked good too! (IMG:style_emoticons/default/driving.gif)
If I could find a set for a reasonable price this is the way I would go. Of course a reasonable price for me now would have to be insanely cheap as I'm still piecing the motor back together after said autocross...
Elliot Cannon
post May 27 2010, 10:55 PM
Group: Retired Members
275/40/17 tires. 11 inch wide rims. Zero offset. 5 1/2 inch back space. 8mm spacers.
RJMII
post May 29 2010, 05:55 PM
Jim McIntosh
J P Stein
post May 30 2010, 08:57 AM
Irrelevant old fart
At some point I've run all kinds of combos.
Presently.....well, you don't want to go there. (IMG:style_emoticons/default/biggrin.gif)
The front end was interesting. At one point I fit a 10 X 16 wheel with a 10 slick.
The backspace was 5 1/2 inches. It required the dust cover of the front shock to be removed. I do some testing for clearance.......full compression of the suspension and lock to lock on the steering and adjust the bodywork to suit....no rubbing allowed.
The above didn't work out well. The wide wheels gave me around 3 (+?) inches of scrub radius giving an un-curable push....oh well.......but it fit with my hand hammered flares. Now there are 8 inch wheels up there (5 inch backspace) and the push is gone with the scrub radius decreased by 1 inch......who'da thunk it?
There's a lesson here for those wanting to run spacers up front.
The rear is much more straight forward. Again the 10 X 16 wheels with a 5 inch backspace. The straight side 10 slicks have about 3/4 inch clearance to the inner fender....enough if I keep at least 19 psi in the tires.......I got the big black marks on the inners at 18 psi *once*.
- Lo-Fi Version Time is now: 15th March 2026 - 03:37 PM
