| jsayre914 |
May 29 2010, 09:17 AM
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,210 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
I have been searching the web for a good HID kit, and i finally went all out and got one. Took a couple of hours to install. Basically it just snaps on to the existing harness and has a few extra wires going into the headlight box. sorry, i had to make a few more holes in my teener (IMG:style_emoticons/default/dry.gif) Then i used the hella h4 e code lense so the beam would not blind any of the opposing traffic. I tucked the ballast right behind each headlight.
My setup runs on 12volt and draws 3.2amps constant. initial startup draws as much as 8 amps. then it puts out a constant 35watts. I choose a color temp of 6000k (sunlight) (IMG:style_emoticons/default/aktion035.gif) Attached thumbnail(s) |
| jsayre914 |
May 29 2010, 09:19 AM
I thought my silverstars were bright, but there color matched the fog lamps. look at the pic with the fogs on, OMG these are cool.
| utah914 |
May 29 2010, 09:25 AM
Member ![]() ![]() Group: Members Posts: 96 Joined: 22-May 06 From: South Jordan, UT Member No.: 6,048 Region Association: None |
Looks great! Can you take a picture at night to show how well it lights up the road? I added HID's on my DD (non-914) a couple of years ago and would never go back.
| zymurgist |
May 29 2010, 09:31 AM
"Ace" Mechanic ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
(IMG:style_emoticons/default/wub.gif)
I'd love to go HID on my RSX, but the JDM HID setup is aimed for people who drive on the wrong side of the road. |
| Mikey914 |
May 29 2010, 10:21 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,778 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
I have a couple hi/low hid kits I brought in to work on a group buy, but had not have the time to do the install myself. Donated a set to Mary Shortridge for the project, and they wound up not getting used. . I really liked these on my 944. The only issue I had was as the light moves it was kind of a pain to get everything mounted so nothing rubs and there's limited space.
I have the bulbs high and low (not just a low HID and high incandecent), with ballasts and wirring from the vehicle plug to the bulb. $64 a set. I have 2 sets. |
Lo-Fi Version | Time is now: 17th April 2026 - 05:44 AM |
