How do you get the most out of a 75' 2.0? |
Type 47 |
Jun 4 2010, 08:40 PM
Senior Member Group: Members Posts: 783 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
I just bought a 75' in excellent condition with only 62k miles. It has has a dual Webber conversion w/o cracking the engine open to put a cam in.
While this car is an excellent survivor I'm pretty sure I'm going to back date the bumpers. dismantel it enough to get rid of the small surface rust in the rear trunk, and at the bottom of the door seams (very minor) and repaint it. I want to get the most out of the GC 2.0 (88 hp) engine. I don't need to go overboard looking for HP...my daily driver has 555 HP and pulls over 1g in corners, so my need for speed won't be from the 914...my need for fun will. In my previous 914's I've never had a true 2.0...a couple of 1.8's with a "big bore" 2.0 kit is what I've had in the past...they would blow the doors oof this 75' 2.0. Granted, I've only had the car a couple days...and the tune is not the best but it just seems way down on power. |
TROJANMAN |
Jun 4 2010, 09:01 PM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
Remove the smog equipment if it is still there.
Backdate the exhaust, preferably to SSI heat exchangers, if not, at least 73-74 stock exchangers, or headers. Ditch the big black rubber bouncy baby bumpers |
tod914 |
Jun 4 2010, 09:16 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Triad and SSE's will get you close to 100hp.
realred914 |
Jun 4 2010, 09:58 PM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
Triad and SSE's will get you close to 100hp. 100 Hp seem a bit high for a low compression smog year motor. even with the auxilary smog stuff removed, it is still low compression. (plus a sucky cam for max power) you could shave the heads a bit if the bottom end is still good enough to handle it. hold on to the smog stuff it is getting valuable specially in smog test states. be aware your state may at anytime require smog tests, so use caution with modifications. good luck!! |
Bleyseng |
Jun 5 2010, 03:16 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Triad and SSE's will get you close to 100hp. 100 Hp seem a bit high for a low compression smog year motor. even with the auxilary smog stuff removed, it is still low compression. (plus a sucky cam for max power) you could shave the heads a bit if the bottom end is still good enough to handle it. hold on to the smog stuff it is getting valuable specially in smog test states. be aware your state may at anytime require smog tests, so use caution with modifications. good luck!! Low compression? The compression ratio from 73 to 76 2.0L is the same, 7.6 to 1 unless you have Euro flat top pistons 8 to 1. Same stock cam as the 73-76 cars so where did the hp go from 95hp to 88hp. The exhaust system! Switch to the 73-74 setup and get the hp back and tune the car up correctly. Make sure it has the carbsI parts so it runs right and clean and rebuild the dizzy so the advance works right. |
realred914 |
Jun 5 2010, 08:46 AM
Triad and SSE's will get you close to 100hp. 100 Hp seem a bit high for a low compression smog year motor. even with the auxilary smog stuff removed, it is still low compression. (plus a sucky cam for max power) you could shave the heads a bit if the bottom end is still good enough to handle it. hold on to the smog stuff it is getting valuable specially in smog test states. be aware your state may at anytime require smog tests, so use caution with modifications. good luck!! Low compression? The compression ratio from 73 to 76 2.0L is the same, 7.6 to 1 unless you have Euro flat top pistons 8 to 1. Same stock cam as the 73-76 cars so where did the hp go from 95hp to 88hp. The exhaust system! Switch to the 73-74 setup and get the hp back and tune the car up correctly. Make sure it has the carbsI parts so it runs right and clean and rebuild the dizzy so the advance works right. some of the power was lost to smog tuning/equipment beyond exhuast. 100 hp is a stretch for this motor with an exhaust change. thats more power than the stock early 914 2.0 motor |
ChrisFoley |
Jun 5 2010, 08:54 AM
I am Tangerine Racing Group: Members Posts: 7,935 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
If you don't mind paying for it, the most power you can get out of an unmodified Type 4 will will come from installing a Tangerine EVO exhaust system.
The torque improvement over your stock '75 exhaust will be 15 lb-ft or more. Peak hp will be above 100. Tangerine EVO 914 Headers |
Tom |
Jun 5 2010, 01:13 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
I can't tell you what the power difference was because I never drove the car before beginning to work on it. It had a leaking trans main seal.
76 2.0. Removed the old exhaust and installed SSHE's and Triad. Then removed all of the smog stuff and stored it. With a fresh tune up it ran great. Even had a more experienced guy try it out and he said it ran like a 2.0. I assumed he meant a presmog 2.0. There is a lot of stuff to do to remove the smog. You will need to cap the air injection pipes at the head near the intake. Also you will need some heater tin from a 74 or earlier to get the heat to work. 75/76 use some different J-pipes, etc. All together less that $1,000. Oh and I love the Triad. I've had people ask me if it is a 6. Ha, I wish! Tom |
Drums66 |
Jun 5 2010, 01:26 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
.....Goose it!!!!!!!!! (IMG:style_emoticons/default/boldblue.gif) (IMG:style_emoticons/default/thumb3d.gif)
P.S. after you do some of the things above? |
Lo-Fi Version | Time is now: 10th June 2024 - 02:30 PM |
