can early rotor and caliper be installed on late strut ?, *** photos added 22 june |
jimkelly |
Jun 21 2010, 02:17 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
can early rotor and caliper be installed on late strut ??
i have this on the drivers side of my 1972 914 ?? jim Attached thumbnail(s) |
underthetire |
Jun 21 2010, 02:51 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Cap'n Krusty |
Jun 21 2010, 03:09 PM
Essentially, no. And it's NOT the mounting bolt spacing. The offset is different for the caliper mounting ears, and they won't center on the disc. I have heard rumor that there "may" be an interim strut in production in late '72, but I've never seen one.
The Cap'n |
Eric_Shea |
Jun 21 2010, 03:24 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I tend to think they "might" but I've never tried it and, I've been told no.
The offset on the calipers is quite a bit different. That is made up on the rotor side. SO... I "THINK" if you move rotors and calipers you "MAY" be safe. I've also heard of the interum strut but, never seen any proof either. I have no more 914 struts laying around, early or late, so I cannot give a definative answer but, I'd like to see EARLY ROTORS and EARLY CALIPERS on a LATE STRUT to see what happens. I could be very wrong... all signs point to that. |
jimkelly |
Jun 21 2010, 03:37 PM
instead of the unicorn strut theory - i am begining to think maybe eric is on to something - that very possibly - an early caliper and rotor can be fitted to a late strut.
before i order a set of early calipers from eric - i want to get one or both my struts replaced with a matching set of early struts - since i recently installed new rotors and bearings. now i want to do ball joints and install rebuilt calipers as my braking is still sub-par. i can squeal my tires under emergency braking at 60 mph but at 30 mph, if i just mildly hit the brake peddle, stoping power feels weak. jim |
underthetire |
Jun 21 2010, 04:02 PM
instead of the unicorn strut theory - i am begining to think maybe eric is on to something - that very possibly - an early caliper and rotor can be fitted to a late strut. before i order a set of early calipers from eric - i want to get one or both my struts replaced with a matching set of early struts - since i recently installed new rotors and bearings. now i want to do ball joints and install rebuilt calipers as my braking is still sub-par. i can squeal my tires under emergency braking at 60 mph but at 30 mph, if i just mildly hit the brake peddle, stoping power feels weak. jim I just did re-build my front calipers and replaced 35 year old hoses this weekend. I will never again complain about 914 brakes again. Now to do the rears. |
jimkelly |
Jun 22 2010, 05:38 AM
i replaced my rubber lines recently.
** if it is determined that a late strut will work with an early rotor/caliper combination, i will just need one late pass side strut. jim |
type47 |
Jun 22 2010, 05:47 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
jimkelly |
Jun 22 2010, 08:20 AM
Joe Ricard |
Jun 22 2010, 01:25 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Hmm, I just always swapped the whole thing.
But yes the only difference is 1/8" spacing difference caliper to rotor centering. I think it is add a washer going early caliper to late strut. 320I caliper to late strut is machine off 1/8" So I might have this backwards. |
jimkelly |
Jun 23 2010, 07:01 AM
anyone have a definitve answer. seems joe might be about right as 1/8 inch is not so obvious to the eye. jim
Eric_Shea |
Jun 23 2010, 05:17 PM
Back in the last thread that addressed this Rich Towle said he would check. (IMG:style_emoticons/default/yawn.gif)
Get on it Rich! (IMG:style_emoticons/default/biggrin.gif) |
jimkelly |
Jun 24 2010, 06:43 AM
new vantage point..
based on this pic - if it is off by 1/8 inch - it is not correctable by using washers. Attached thumbnail(s) |
914rat |
Jun 24 2010, 10:51 AM
Member Group: Members Posts: 279 Joined: 3-July 06 From: Maryland Member No.: 6,362 |
Jim, I have some core struts of both type and I'm just across the bay in Md.
Eric_Shea |
Jun 24 2010, 01:41 PM
Offset on the calipers is much greater than 1/8th"
r_towle |
Jun 26 2010, 08:34 AM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Late strut, early calipers/rotors WONT fit.
Early strut, toss it...it has the crappy ball joint anyways. I never bothered to try later rotors/calipers on an early strut....I replaced the early strut and went the other way. I will be in the shop today, Eric....tell me what measurements we need, I will take a look and see what I have left. Rich |
Lo-Fi Version | Time is now: 12th June 2024 - 06:04 AM |
