Muffler Temp Paint, How Hot? |
bandjoey |
Jun 21 2010, 03:56 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
I had a can of Rust Oleum Flat Black on the shelf. Thinking it's a good color to cover the original muffler, I Painted. Looks good. About midnight it hit''s me...High Temp??? (IMG:style_emoticons/default/huh.gif)
The can label shows it ok up to 200degrees. So...how hot does the muffler get? If it's not going to work, can I paint a high temp paint on top, or do I need to strip this off? (IMG:style_emoticons/default/chair.gif) |
underthetire |
Jun 21 2010, 03:58 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
It will be gone the first run. Even the high temp stuff comes off after a while usually. You need to get all that off before you put high temp on it, otherwise it will burn the paint under it and just start flaking off.
Tom_T |
Jun 21 2010, 04:34 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
It will be gone the first run. Even the high temp stuff comes off after a while usually. You need to get all that off before you put high temp on it, otherwise it will burn the paint under it and just start flaking off. (IMG:style_emoticons/default/agree.gif) .... but you'll probably see a mess of smoke as it burns off, esp. with Rustoleum's additives! (IMG:style_emoticons/default/barf.gif) Get all the Rustoleum & now crappy original paint off, then get some VHT or similar high temp paint - IIRC you need 1400 degee stuff on them - both primer & paint. As with headers/HE's etc. good prep & good priming is as important as proper hi-temp paint. BTW - stock color was a flat or satin grey, although many prefer black. VHT is available at most FLAPS, but here's a link for their colors & primers: http://www.vhtpaint.com/ http://www.vhtpaint.com/flameproof.html Here's the 356 resto supplier with the same Porsche exhaust system grey which those guys & many of the CW's here use: http://www.nlaparts.com/store/exhaust-grey-paint-p-653.html (IMG:style_emoticons/default/popcorn[1].gif) |
EdwardBlume |
Jun 21 2010, 04:49 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
I used BBQ paint which came out flat black. I also polished the tip which came out real nice....
We'll see how it holds up but the can says 1400 deg... |
Socalandy |
Jun 21 2010, 06:40 PM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
VHT works great and after six months and more than 2K of driving its still like the day I painted it.
bandjoey |
Jun 21 2010, 07:59 PM
Ok Thanks. I'll slime it tomorrow with paint stripper.
Tom_T |
Jun 23 2010, 02:51 PM
I used BBQ paint which came out flat black. I also polished the tip which came out real nice.... Yeah, but how do the weiners & patties turn out Rob?? (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/jsharp.gif) ... & don't spend too much time polishing the tip! ... you kill me!!!! (IMG:style_emoticons/default/lol-2.gif) |
gothspeed |
Jun 23 2010, 05:03 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
No need for extra chemicals with the paint stripper. If you don't mind the extra remove/install, the hot exhaust will 'strip it for you (IMG:style_emoticons/default/smile.gif)!
Ericv1 |
Jun 23 2010, 05:11 PM
Member Group: Members Posts: 259 Joined: 30-December 07 From: Cincinnati, Ohio Member No.: 8,518 Region Association: Upper MidWest |
Seymour makes a high temp paint called "Cast Blast". It's a flat grey and is used on heads for V8's. I liked the color and used it on a friends 911 headers and it came out great and withstood the heat after many miles of use. |
fat73 |
Jun 23 2010, 07:59 PM
W9R1 Group: Members Posts: 244 Joined: 7-May 05 From: tampa,fl Member No.: 4,043 Region Association: South East States |
bandjoey |
Jun 23 2010, 10:05 PM
VHT header paint is rated on the can from 1300 - 2000 degrees, Guess that will cover it ok and it comes in ORANGE. (IMG:style_emoticons/default/cheer.gif) The FLAPS aircraft paint stripper cut the old paint off in no time. Messy but it's easier than sanding and not as smelly as burn off.
Lo-Fi Version | Time is now: 11th June 2024 - 05:46 PM |
