Brake Pressure Regulator or "T" Fitting, what combos are elgible |
project-914 |
Jul 21 2010, 01:52 PM
Member Group: Members Posts: 181 Joined: 2-August 06 From: Oklahoma Member No.: 6,571 |
I have looked all over only to find a few threads
I have learned that the regulator restricts pressure to the rear as to eliminate rear lock ups what if I upgrade to a 911 front and a 19mm MC... then is a "T" fitting appropriate? who does the calculations here, I need info and brake balance and hopefully not a regulator! thanks, JOhnny |
Tom_T |
Jul 21 2010, 02:07 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
The 914-6's had as OE essentially the 5-lug 911 front end & brakes F&R with the 19mm MC & still used the same regulator in the back as for the 914-4 4-lug brakes & 17mm MC - so it should work just fine with your OE regulator IMHO.
I'm changing to a 19mm MC on my 73 2L as part of the resto - with the stock brakes, & will keep the stock regulator. Send a PM or email to Eric Shea at PMB (member vendor on here) & let him know what you're trying to accomplish & he can help you, as he's the real "914 brake guru"! (IMG:style_emoticons/default/pray.gif) http://www.pmbperformance.com/calipers.html |
SLITS |
Jul 21 2010, 05:31 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Two six conversions using "T"s ... haven't locked up the rears yet ... "S" calipers upfront and stock /4 rears.
Oh well ... and the pressure settings were different with the /6, but a stock /4 will work. RTM. |
hydroliftin |
Jul 21 2010, 06:06 PM
Member Group: Members Posts: 373 Joined: 8-November 06 From: Vallejo, CA Member No.: 7,180 Region Association: Northern California |
I have looked all over only to find a few threads I have learned that the regulator restricts pressure to the rear as to eliminate rear lock ups what if I upgrade to a 911 front and a 19mm MC... then is a "T" fitting appropriate? who does the calculations here, I need info and brake balance and hopefully not a regulator! thanks, JOhnny I think this thread with much input from Eric Shea is the only one you need to read: http://www.914world.com/bbs2/index.php?act...=2&t=104464 Pay particular attention to the attachment Eric provides to a Alfa Romeo technical bulletin and the graph of how brake preassures are affected by the regulator. I think one might conclude that it is a good thing to retain the regulator even in the stituation you describe. |
Lo-Fi Version | Time is now: 10th June 2024 - 11:17 AM |
