Ground Light Out and No Charge - HELP |
vesnyder |
Aug 26 2010, 07:05 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
I did a search and could not find anything, but where should I start - I noticed when I started my 914 last that the "charge" light on the dash was not lit. After I started the car I also noted that my Voltmeter, which usually shows 14+ volts is showing 12, and lesss when I load up the charging system with lights and fog lamps. What are the typical culprits?
Cap'n Krusty |
Aug 26 2010, 07:37 PM
The fuse that powers the light, the bulb, the regulator, the wiring, and the alternator.
The Cap'n |
vesnyder |
Aug 27 2010, 08:13 AM
Thanks! Went in and removed the electrical cover in teh engine compartment and checked all the connections there and the light came on and the batter is now charging! A bit disconcerting that I do not know exactly which connection is teh issue, but I narrowed it down.
Thanks again! The fuse that powers the light, the bulb, the regulator, the wiring, and the alternator. The Cap'n |
dr914@autoatlanta.com |
Aug 27 2010, 08:47 AM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
maybe the voltage regulator was not making a good connection! Make sure that it is secured with the two tiny domed headed screws
Thanks! Went in and removed the electrical cover in teh engine compartment and checked all the connections there and the light came on and the batter is now charging! A bit disconcerting that I do not know exactly which connection is teh issue, but I narrowed it down. Thanks again! The fuse that powers the light, the bulb, the regulator, the wiring, and the alternator. The Cap'n |
ldsgeek |
Aug 27 2010, 09:59 AM
Member Group: Members Posts: 155 Joined: 27-June 10 From: New Hampshire Member No.: 11,885 Region Association: None |
I still hate the German style fuses from when I had a BMW 320i. Occasionally I would have to twist the fuses and r&r the relays so the car would start. When I get my 914 (i pick it up Sept 4 (IMG:style_emoticons/default/smile.gif) ) I am thinking of installing the modular replacement fuse panel I have seen just to avoid this problem from the start.
windforfun |
Aug 27 2010, 11:47 AM
Senior Member Group: Members Posts: 1,823 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Try some contact cleaner (Fry's or Radio Shack) & a fine wire brush. Keep it stock.
underthetire |
Aug 27 2010, 12:35 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
I still hate the German style fuses from when I had a BMW 320i. Occasionally I would have to twist the fuses and r&r the relays so the car would start. When I get my 914 (i pick it up Sept 4 (IMG:style_emoticons/default/smile.gif) ) I am thinking of installing the modular replacement fuse panel I have seen just to avoid this problem from the start. You'll still have to deal with them on the relay board. |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:02 AM |
