What dellorto setup should I use for a 1.7 ? |
theo |
Aug 30 2010, 02:34 PM
Newbie Group: Members Posts: 26 Joined: 4-December 07 From: Vancouver WA Member No.: 8,417 |
I had a pair of dellorto carbs that were on a 2.0 engine, the engine was no longer being used so I put them on a 1.7 engine I have in my car to replace the single weber that I had been using. When I installed them on the 1.7 engine, the car idled at around 2k rpm. My question is what dellorto jet setup works well on the 1.7, I think what I have are 40’s, I assume that is much too big for this engine, also where could I find the parts or jets I need? (I don’t know very much about carbs)
ME733 |
Aug 31 2010, 07:00 AM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
I had a pair of dellorto carbs that were on a 2.0 engine, the engine was no longer being used so I put them on a 1.7 engine I have in my car to replace the single weber that I had been using. When I installed them on the 1.7 engine, the car idled at around 2k rpm. My question is what dellorto jet setup works well on the 1.7, I think what I have are 40’s, I assume that is much too big for this engine, also where could I find the parts or jets I need? (I don’t know very much about carbs) ..........Dellorto made ...36 mm butterfly... carbs with 28 mm venturis.(labled DRLA 36)...They work very well on small displacement engines....(1700,cc)....parts, rebuild kits and jets are available.............I have a set with no planned use in the forseeable future....and they have been preserved properly, in silicone oil. |
jsaum |
Aug 31 2010, 10:59 AM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
I have a set of 36's where can you get parts?
Thanks, Jsaum |
jsaum |
Aug 31 2010, 11:05 AM
I found the kits on cb performance's site, it's the floats that aren't available. Anyone have an idea on the floats? Sorry if I'm hijacking the tread!
Jsaum |
Lo-Fi Version | Time is now: 8th June 2024 - 10:11 AM |
