> cylinder head temp sensor, cylinder head temp sensor
2Lyelo914
post Sep 1 2010, 03:27 PM
Any procedure on putting this in a '74, 914 2.0L?
Thanks.
Jim
underthetire
post Sep 1 2010, 03:43 PM
Soak the old one in PB blaster for days before you try and remove it.
avidfanjpl
post Sep 1 2010, 06:12 PM
914 Hemophiliac
A lot of us took a long 13mm socket and dremeled out a channel so the wire can avoid getting squashed.
I have removed and installed 3 lately, so I removed the injector connectors from the injectors, took off the injector pipes completely, then had all the room I needed to remove the rubber grommet and install the CHTS with nothing in the way.
I then put the stuff back, and it took 10 minutes. Even in 100 degree heat.
I also removed the deceleration valve and the MPS first. Makes for easy access.
John
Gint
post Sep 1 2010, 08:20 PM
Mike Ginter
Moving to the garage...
Jeffs9146
post Sep 1 2010, 08:32 PM
Ski Bum
I ground a notch in an extension to fit the wire through then you can save your 13mm!
McMark
post Sep 2 2010, 01:12 PM
914 Freak!
Are we talking fuel inject CHT? Or aftermarket dash gauge CHT?
malaga_red75
post Sep 2 2010, 02:02 PM
'74 2.5L N/A Subie
QUOTE(Jeffs9146 @ Sep 1 2010, 07:32 PM) *
I did this too, about half-way up a long-sleeve 13mm just cut out a notch and slipped the wire through.
-peter
majkos
post Sep 2 2010, 03:16 PM
QUOTE(McMark @ Sep 2 2010, 11:12 AM) *
Sounds like they're talking about stock temp sensor
aftermarkets are way to easy to install
Here's what I made to deal with the stock sensor
- Lo-Fi Version Time is now: 10th June 2026 - 03:34 AM
