| Krieger |
Sep 2 2010, 07:43 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,862 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
Last night I woke up thinking of a second redundant hydyraulic system for the rear brakes only. Perhaps a T-1 master, or some small slave cylinder attatched to a handle that could apply force for braking....Then I says to myself "self you could plumb this into the existing line going to the rear of the car and put a one way valve in that line to keep it pumping the rears only" Also a one way valve would be need to protect the e-brake pump from the main master cylinder. I know a cable is the ultimate redundant system, but this could be a cool compromise keeping complexity/weight/junk off those rear wheels. (IMG:style_emoticons/default/first.gif) or : (IMG:style_emoticons/default/stromberg.gif)
(IMG:style_emoticons/default/popcorn[1].gif) |
| Mark Henry |
Sep 2 2010, 07:46 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Last night I woke up thinking of a second redundant hydyraulic system for the rear brakes only. Perhaps a T-1 master, or some small slave cylinder attatched to a handle that could apply force for braking....Then I says to myself "self you could plumb this into the existing line going to the rear of the car and put a one way valve in that line to keep it pumping the rears only" Also a one way valve would be need to protect the e-brake pump from the main master cylinder. I know a cable is the ultimate redundant system, but this could be a cool compromise keeping complexity/weight/junk off those rear wheels. (IMG:style_emoticons/default/first.gif) or (IMG:style_emoticons/default/popcorn[1].gif) Not a legal E-brake, must be mechanical. |
| Eric_Shea |
Sep 2 2010, 08:21 AM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Hot brakes and fluid (what they are when you usually set it) always cool. This is why they insist upon the cable/mechanical set-ups.
| 76-914 |
Sep 2 2010, 08:23 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,896 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Mark's right, but if you must.......... http://www.aircraftspruce.com/catalog/lgpa...gbrakevalve.php
| Mike Bellis |
Sep 2 2010, 08:40 AM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
I'm running one of these. the PO gutted the parking brake system.
| Krieger |
Sep 2 2010, 08:56 AM
Damn I thought I came up with a new Flux Capacitor, but this looks easy. How much was it. But again not street legal set up according to mark. but the only thing I would want this for is for a true emergency brake, not a "parking brake"
| jmill |
Sep 2 2010, 09:34 AM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
If you want a true E brake then the last thing you want to do is plumb it into the existing line. A ruptured line = no brakes. Mechanical is the only way to go if you want to stop in an emergency. I've had all kinds of failures from ruptured lines, failed master cylinders, leaking pistons and pads ripping out of the calipers. Without a mechanical back-up I wouldn't be here typing this.
| davep |
Sep 2 2010, 11:39 AM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,363 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Federal law requires a functional, and mechanical, emergency brake.
The parking brake is a secondary and lesser function of the emergency brake. Street or track, everyone else has a right to expect that your emergency brake will function in the event of a hydraulic failure. |
| McMark |
Sep 2 2010, 01:10 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Don't some people use a 'line lock' to keep pressure on the rear brakes. With that you park your car, step hard on the brakes close the 'line lock' valve, and then it maintains pressure in the rear calipers.
That being said, I'm a STRONG believer in the mechanical EMERGENCY brake. It's not a parking brake. It's for that 1% chance where you say, "OH SHIT!" and that little level saves your life or your car. |
| SirAndy |
Sep 2 2010, 01:18 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,483 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Don't some people use a 'line lock' to keep pressure on the rear brakes. With that you park your car, step hard on the brakes close the 'line lock' valve, and then it maintains pressure in the rear calipers. You still have the problem of losing pressure when the brake fluid cools ... (IMG:style_emoticons/default/shades.gif) Andy |
| Sleepin |
Sep 2 2010, 01:45 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
Is a wood block mechanical enough? (IMG:style_emoticons/default/laugh.gif)
| McMark |
Sep 2 2010, 01:55 PM
NEVER use a wood block. The appropriate tool is a brick. (IMG:style_emoticons/default/tongue.gif)
| Sleepin |
Sep 2 2010, 02:04 PM
That also doubles as an "Emergency Entrance Device"! (IMG:style_emoticons/default/biggrin.gif)
| 914four |
Sep 2 2010, 10:55 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 525 Joined: 4-March 07 From: Rainbow City, Alabama Member No.: 7,582 Region Association: South East States
QUOTE Not a legal E-brake, must be mechanical. Can the mechanical brake be on the front? |
| messix |
Sep 2 2010, 11:30 PM
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
Don't some people use a 'line lock' to keep pressure on the rear brakes. With that you park your car, step hard on the brakes close the 'line lock' valve, and then it maintains pressure in the rear calipers. That being said, I'm a STRONG believer in the mechanical EMERGENCY brake. It's not a parking brake. It's for that 1% chance where you say, "OH SHIT!" and that little level saves your life or your car. "line lock" is used by drag racers to lock the front wheels to do a burn out with out crossing the starting line. line lock is not a emergency brake, it's a valve that closes to "lock" the pressure to the brake circuit that it is installed on. i would not trust the primary hydraulic system as an emergency brake. and to do a simple mechanical disc brake set up to the half shaft at the tranny would be so simple. |
| sixnotfour |
Sep 2 2010, 11:42 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,272 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
I am suprised Troy didnt mention this setup , old school fourwheelers used this for hill holding and winching,
supplementary brake lock must be reapplied every hour has low pressure warning, other models have a pump to maintian pressure http://www.mico.com/store/brake_locks |
| messix |
Sep 3 2010, 12:26 AM
I am suprised Troy didnt mention this setup , old school fourwheelers used this for hill holding and winching, supplementary brake lock must be reapplied every hour has low pressure warning, other models have a pump to maintian pressure http://www.mico.com/store/brake_locks we used those on our bucket trucks.... but now they are not used and are not osha approved. standard e-brake and chock the wheels is the only osha approved method. micro locks used to be used off road but have fell out of use because of some accidents where people depended on the micro lock and were winching from out side the vehicle. the vehicle moved with no driver to correct or prevent the movement, bad things happened.... not used any more. micro locks are not an emergency brake nor are they a parking brake! seals leak, fluid cools, pressure subsides = bad things |
| MoveQik |
Sep 3 2010, 12:57 AM
What size wheels can I fit? ![]() ![]() ![]() ![]() Group: Members Posts: 4,668 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
Both are great but very tricky to hang out the window at 50+mph and place it *just right* At that point I would only recommend using when you have a co-pilot available. I mean....let's be safe out there. |
Lo-Fi Version | Time is now: 15th June 2026 - 03:39 AM |
